Question about Philips 55P8241 55" Rear Projection Television
Dirty screen How and What do i use to clean the inside of my 55" projection tv screen
  • mick557
    mick557 Feb 26, 2008
    i have a rear projection tv (Sony KDF-50E2010) and have a dirty mark internally about 4 inches from the top right hand corner.
    how can i dis assemble the tv and what do i use to clean it? thanks
    Scholar:
  • 148 Answers
Http://www.screenkleen.com/index.html That stuff is the best you'll find. Ever. You'll need to take your TV apart to access the inside of the TV. Take the speaker grille off and possibly assembly frame surrounding the TV(They usually snap off) you should find screws under that to further assist with disassembly.
Posted on May 09, 2006
No power and dirty screen on inside
If no power the possible problem is the fuse, the power supply detector, power IC. The dirty screen cause by over voltage in your TV. This is due to defective power supply...
Call a technician to repair your TV
Sep 19, 2011 | Philips 55PW9363 55" Rear Projection...
My sanding 55 in rear projection tv has several hundred dots on the screen and getting worse each day. How can this be fixed?
u need to unplug tv, remove cover of upper back portion which is behind the screen. u will see a mirror fitted on inside of back cover clean both screen, mirror. u will also find on bottom side 3 picture tubes. clean them as well.
Aug 25, 2011 | Samsung Televison & Video
How to make the picture to a Philips 2002 rear projectiontv clear
needs to replace the liquid in the tubes of blue and green projection
Jan 06, 2010 | Philips 55PW9363 55" Rear Projection...
How do i clean the screen inside of ws-55613 55"
You will have to take the lower back off of the TV with the power off of course for safety. Only use like a Swiffer to reach in there to clean if the only issue is spider webs. If you use anything else you will end up scratching the screen assembly and they usually run between 300-500 for the assembly. Please take a few minutes to rate my answer...Thank you. :)
Nov 17, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Blue and red shadows on the TV picture
open up the TV then clean up the silver screen and the 3 light bulbs inside its probably just dirty.
Oct 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Phillips
Hi. I had the same problem with my Philips RPTV and the fix is extremelly ease. You just need to open the back cover (mine uses torx screws). Inside the tv is very mechanic. You will find the three CRTs and most likely the lenses are dirty. You just need to wipe them off with a soft cloth. Also the CRTs project the image not directly to the screen, but to a big mirror and that mirror will be most likely dirty (like when you open the hot water in front of a mirror). Once you clean the mirror and the crts, your tv will like as the they you got it.
Jan 24, 2008 | Philips 55PP9502 55" Rear Projection...
Water stain on the front of our Akai PT5499 Projection TV
Hmm... should evaporate on its own. The only way to access behind the screen is to take the whole back off the TV, and then inside theres another panel that covers the main reflector and screen. I wouldnt recommend doing that just for water tho.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Inside the cabinet projected on the screen?
well . there are 4 things that can cause this..
1= the outer screens could be dirty.clean with screen protector cleaner.Spray on cloth and not on outer screens.
2= outside lenses of picture tubes could be dirty.Unit can be opened .Outside lenses can be cleaned with a lens cloth .Do not use paper towels or cotton as this my scratch surfaces of lenses.
3= inside of picture tubes could be dirty.This should be done by a repair shop only(dirty coolant inside tubes)
Dec 28, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55P8241 55" Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
