Hi,you need to jack car off the ground,and put selector in refirst and aply hand brake,undo the gear leaver from the gearbox then manualy put the gear selector in park position then ajust selector linkidge so that it will go back on without pulling the gear selector out fom its position,if it dose not pick up park now there must be something wrong with the gearbox.
hope this was some help.
Sounds definetly like the Trans shifter linkage needs adjusted-normally not needed unless accident damage or simple wear/loosening of linkage(usually rite at trans is the adjustment)
Jack up the truck and see if brakes are locked.. or just try pushing it if it rolls its probably a trans problem not a brake problem. could be the park prawl is broken in the Trans.
The parking brake can be bad or stuck. There is not much to them to begin with. For the transmission, there are several potential problems.
You may just need an adjustment, as the Park is on one extreme end of the shift from the rest. It may not quite be locking.
Inside the trans there is a lever called a pawl. Can't say why it is called that but it is suppose to wedge between gears notches inside the trans. This is suppose to lock the shaft. If the pawl lever is broke, it has no end to jam in its position. The broken part would be loose inside the trans.
I see that you were on a driveway. It could do it anywhere. Remember Driver training to hook front wheels toward downgrade hills and for the back of the front wheels to hook the curb on upgrades when parallel parking.
Even so, the Parking brakes are not that good to depend on when the trans does not lock in place. Take it somewhere to check trans linkage.
On the 1995 Jimmy, the shift cable can come loose on the mount on the side of the transmission where the cable meets the trans. When it slips, the alignment goes off and causes the driver to not be able to put the trans into park. If you take a long stick you can push the shift arm on the trans to the park position and your trans will go into park.....what you (and I) really need to know is how to take the shift cable mount apart and reset it.
Change fluid and trans filter check magnet in trans pan for metal clean pan with a rag refill with senthic fluid leave a court low let it idle till hot then add a bottle of trans x or lucas leave idlen work the trans from 1st to park letting the trans take gear an let it stay in gear for a little bit then back to park that help move the fluid threw the trans drive easy for a week ir you Lucas pore half qurt of trans fluid in use the rest of fluid to thin down Lucas its really thick repeat till the bottle of lacus is in I hope this helps
