I'm not sure exactly what your problem is. When you "click" your lights to low beam, your high beams should not work. But if your low beams work when you "click" them on, but your high beams don't work when you "click" them on, you either have a blown fuse, bad relay or high beam elements burned out on both lamps. (Not so unusual) Possibly a bad "dimmer" stalk switch or bad wiring, too, but a little less likely.
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
