Question about Dewalt Saws
Dewalt Table Saw
My (13) Yr. Old 10" Dewalt table saw is making a lot of noise, sounds like a motor bearing, blade has some from free play as well. I can't locate the model number?
Is their a Dewalt repair shop in the Cleveland area?
Help Appreciated
R. Kups
robertkups@yahoo.com
  • Anonymous Mar 13, 2014
    how to attach dewalt table saw dw745 to dewalt table dw745
    need instructions on how to put dewalt table saw to dewalt dw745
    Problem Solver:
  • 8 Answers
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Posted on Oct 01, 2008
Severe vibration with Dewalt 744S Table Saw
try it with no blade
if you have unhabitual noise and vibration,probably need to change bearing
if you do not have a bearing puller do not try to do it yourself
professionals will take 2 to 3 times less time than you do the work and if there is something else damaged, (gear damaged,) he will see it and inform you
Sep 22, 2012 | Dewalt DW744S 10" Portable Table Saw with...
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
Sep 27, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
Bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Jun 01, 2010 | Bosch 4100 10" Worksite Table Saw
Nut that holds the blade loosens after one cut. saw also runs loud and rough. believe is it related to the "gears" and cause of the nut loosening.
Sounds like a bearing is shot and rattling up the works there. Rock the blade back and forth and see if there is any play in it, check the bearing at the other end of the shaft. Is this one of those skil saw motor saws? Or is the motor hanging down below the blade? Need to know that before I can tell you what it is.
Mar 14, 2010 | Craftsman 10" Table Saw
I have table saw and the motor stop the work but make a noise like it want starter but is just the noise
check the output shaft to the blade side. the set screw on the arbor may have come loose
Jan 15, 2010 | Craftsman 10" Table Saw
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Blade Height
Basic saw safety dictates that the blade should barely clear the thickness of the material being sawed. This has saved my fingers more than once, Also, make sure you use a push stick for thin rips. They are a lot easier to replace than fingers, and are easily made from scrap stuff. As for the blade diameter, you want to use a 10" blade, but on occasion a smaller blade can be used, just be sure the arbor doesn't rub against the bottom of the table. Dado blades for 10" saws are usually only about 8" in diameter.
Aug 27, 2008 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
392 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
