Question about Midland WR-100 Weather/RDS Radio
Automatic Weather Alert
Have Weather Alert Radio WR-100 (9/05/08). Weather Alert does not come on automatically. Must push Weather/Snooze button to hear broadcast. What must I do to get automatic alert. I am using frequency 162.475 and 162.400. Please reply.
John J. Krehbiel
Krehgil@embarqmail.com
Weather Radio WR.100 was defective. Returned unit to retailor for replacement. Problem solved.
No further action required.
Krehgil
Posted on Sep 13, 2008
Intermittent beeps
I get this when it loses the radio signal. I have to unlug it and remove/replace the batteries to reset the stations. You might also try hitting the weather/snooze button, listen to the quality of the reception and then move the antenna around to try and find good reception. These radios are picky about antenna reception location.
Dec 23, 2012 | Midland Radio Midland WR 120 - Weather...
Midland Weather Radio Will not give a weather report
Have you gone into the setup mode and adjusted the voulme setting?
Just a thought. The volume may be turned down too low.
Mar 25, 2012 | Midland WR-100 Weather/RDS Radio
Where is reset button on midland wr-100 weather alert radio
I am not receiving any radio broadcast on the freq. that my radio is supposed to pick up. radio is on correct region code. What can I try?
Feb 26, 2012 | Midland WR-100 Weather/RDS Radio
Weather radio just gives off high pitch squeal and no weather info.
If you hold the WEATHER/SNOOZE button and the VOLUME UP button, it resets the radio to its deafult factory settings.
Jan 20, 2012 | Midland WR-100 Weather/RDS Radio
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
I have a Midland WR-100. The stations don't work, it just rings. Can I fix this?
Good morning, afternoon, evening or night; whatever time you're reading this. Your complaint is that the stations on your radio do not work and it just rings for no apparent reason? The possible cause of this could be your alert setting. Your alert setting may be set on TONE. When this setting is activated, a ringing sound will be played on your radio for 5 minutes or until any button other than the Weather/Snooze button, on your radio is pressed. If this is the cause to your problem, you need to change your alert type setting. Here are the steps to doing this task...
  1. Press the MENU button.
  2. Use the directional up button until "ALT TYPE" is showing on your screen.
  3. Press SELECT
  4. Using the directional up or down buttons, choose DISPLAY or VOICE.
  5. When this is done, press SELECT.
  6. Press the directional up button until "ALT TEST" is shown on the screen.
  7. Test your alert type to find out if you'd prefer this setting.
  8. If this setting is preferred,press SELECT and MENU to exit. If you prefer to choose another setting, press MENU, then the directional down button until "ALT TYPE" is showing on your screen. Repeat steps 3 through 8.
I hope this solves your problem. Reply back if it doesn't. Thank you for choosing FixYa as your one-stop solution spot for your problem. Make sure to read our Tips & How-to page for this product. Have a good morning, afternoon, evening or night; whatever time you're reading this solution.
Apr 19, 2011 | Midland WR-100 Weather/RDS Radio
Our radio has never sounded an alert. It is programmed for Wabash County, Indiana, code 018169, and is plugged into an outlet. It has no batteries in it. Does it require batteries to work? The...
The answer to your first question is no, but the company that made this product and even I suggest that you put 3 AA batteries in the radio for back-up just in case you have a power outage. Maybe you had a power outage and that's why it didn't sound an alert. The possible answer to your second question is that it the storm itself may have not been severe enough for the NWS to issue a severe storm. You should check these websites for more information- http://www.crh.noaa.gov/lsx/?n=nwrfaq & http://www.weather.gov/nwr/nwrwarn.htm. FAQ #10 on the first website listed should give a clarification to you problem. They have certain criterias for issuing a warning and sounding an alert. The second website should give you a clarification on when the NWS sounds an alarm.
Aug 06, 2010 | Midland WR-100 Weather/RDS Radio
My midland radio buzzes....no weather report when i hit the wather snooze button just buzz
Have you checked the seven (7) frequencies offered to find the best reception?
Jan 06, 2010 | Midland WR-100 Weather/RDS Radio
Radio does not alert
set it for county code 99999. make sure you can hear the station when you press the WEATHER button. You should see NOAA in the display window. The radio is tested every Wednesday between 11am and 12 noon and you should have a TEST message every Wednesday if it is working. You can set it for Display only, Voice or Siren, so check your menu settings, okay?
Aug 20, 2009 | Midland WR-100 Weather/RDS Radio
Manual
Hi, not sure why the manual I uploaded doesn't show up anywhere so here it is in 2 posts (too large for 1 post)
Stormtracker Vector Model: VEC438 Classified: UNOFFICIAL USE AT YOUR OWN RISK!
Programing Instructions
To Program Alert:
Turn the radio on and then press:
1. Menu button (may have to hold it a few seconds) and Alert should show in the Display.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: Voice/Siren/or Off.
3. Then use the Menu button to select between Voice/Siren/or Off.
3. After making your selection, press the Memory button to the left of the Menu button. This completes the programming of the alert function.
Example: If "Siren" is displayed on the LCD screen and you push the Memory button to the left of the Menu button, when a weather alert is broadcast the siren tone will sound and the appropriate yellow or red light will activate. If "OFF" is displayed on the LCD screen and the Memory button is pushed, the alert will not activiate.
To Program County
1. Menu button (may have to hold it a few seconds) and when ALERT appears, tap Menu button to scroll to County.
2. Press Channel/Snooze button to the right of the Menu button which will display one of the following: All/Multiple/or Single
3. Then use the Menu button to select between All/Multiple/or Single (You'll need to know the S.A.M.E. codes for the area you want to listen to, otherwise select ALL and you will recieve "All" Statements, Watches & Warnings without having to select a specific County).
4. After making your selection, press the Memory button to the left of the Menu button if ALL was selected or Channel/Snooze button to the right of the Menu button if you chose Multiple or Single (You'll see CODE01 on the display) If you chose Multiple use the Menu button to choose which Code Position to enter (01-10) then press the Channel/Snooze button to the right of the Menu button. Enter the first digit of the S.A.M.E. code then press the Channel/Snooze button to the right of the Menu button to move to the next digit of the S.A.M.E. code. Repeat this for all digits of the S.A.M.E. code. Then press the Memory button to the left of the Menu button to lock in that code. Press the Menu button to select the next code position to enter. Then press the Channel/Snooze button to the right of the Menu button, then the Menu button to select the digit of the next S.A.M.E. code to be entered. Repeat these steps as necessary to enter in all the S.A.M.E. codes you wish to enter, each time pressing the Memory button to the left of the Menu to lock in each code position. When completed entering in all S.A.M.E. codes press the Memory key again to lock in all codes and return to normal operation. This completes the programming of the County Code function.
Example:
COUNTY SAME # NWR TRANSMITTER FREQ. CALL SIGN WATTS
Fulton 013121 Atlanta 162.550 KEC80 500
Colquitt 013071 Pelham 162.550 WXK53 1000
Colquitt 013071 Valdosta 162.500 WWH31 1000
NOAA Weather Radio Frequencies
162.400 MHz (WX2)
162.425 MHz (WX4)
162.450 MHz (WX5)
162.475 MHz (WX3)
162.500 MHz (WX6)
162.525 MHz (WX7)
162.550 MHz (WX1)
Channel numbers, e.g. (WX1, WX2) etc. have no special significance but are often designated this way in consumer equipment. Other channel numbering schemes are also prevalent. Best to just tune to the strongest sounding station in your area, this radio does not display frequiencies, only channel numbers.
NOAA Weather Broadcasts
Channel Frequency
1 162.550
2 162.400
3 162.475
4 162.425
5 162.450
6 162.500
7 162.525
A link to get the S.A.M.E. codes for your listening area: http://www.nws.noaa.gov/nwr/indexnw.htm
Aug 18, 2008 | Vector VEC438 AM/FM/Weather Radio
Midland WR-100 Weather/RDS Radio Logo
442 people viewed this question
Top Midland Audio Players & Recorders Experts
John
John
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
