Re: My 2002 Santa Fe is locked and the remote will not...
First of all, has the burglar alarm been activated? If so, you can enter the vehicle with the key, put the key in the ignition and turn it to 'RUN' or 'ON" and then wait 3 to 5 minutes for the burglar alarm to stop. You should then be able to start the engine. You still need to have a qualified/certified Hyundai Service Technician properly diagnose the problem with the remote (Keyless Entry & Alarm System).
? 9:37 https://www.youtube.com/watch?v=jsQcLya1YLQ
Jan 24, 2014 - Uploaded by jimthecarguy
No Start Cranks Ok No Injection Pulse 2002 Hyundai Accent Easy Step By Step ... Jimmy, i strugle to start my trajet 2.5 v6 after installig new engine. ... type of hyundai accent 2002, the engine cranks, but It won't start, no spark, ...
? 9:37 https://www.youtube.com/watch?v=ecLmYPcWipo
Feb 11, 2014 - Uploaded by jimthecarguy
2002 Hyundai Accent No Start ,Cranks Ok Spark OK ,No Injection Pulse My car will not start what should
About 1,770 results (0.59 seconds) Search ResultsHyundai Santa Fe Electrical Problems - Edmunds.comforums.edmunds.com > Hyundai > Hyundai Santa FeMay 8, 2007 - 31 posts - 24 authorsLearn more about Hyundai Santa Fe at the Edmunds.com Car Forums! ... and whether it left an error code on the computer when I next take it to the shop. ... My Hundai Sante Fe 2002 has been having strange electrical issues ... It does not have a remote starter but does have an alarm and electonic key."No Start" Due to Drive Authorization's Failure to ... - RepairPalrepairpal.com > Problems > Mercedes-Benz > ML350In many cases, a new module and keys will be needed to correct this ... Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer, Hyundai, Infiniti, Isuzu ... my 2005 mercedes benz ml350 would not start, it telling me star error. ... Says key not detected, I changed batteries. .... Mercedes-Benz Repair in Santa Fe Springs, CA.Missing: 2001 errHow do you start the car with the key in the console slot ...www.hyundai-forums.com/.../149516-how-do-you-start-car-key-console...Oct 5, 2012 - 10 posts - 7 authorsI had an incident yesterday where the car did not seem to detect my key. When I pushed the ... The manual says if the battery is weak to insert the smart key into the center console slot to start the car. Well ... 2013 Sonata Limited 2.4L 2011 Santa FeGLS 2.4L 2001 Santa Fe GLS 2.7L .... HTML code is Off.Missing: error errdb:: 4.99::Blue screen Error FE 9p
their is a way to do it but recheck battery first sometimes the relearn process doesnt work or the fob itself is dead also if auto /remote start will need dealer to flash fob ---- 2002 santa fe and followed programming instructions and eventually was able to program the new remote. But, I did not realize I had to program my existing remote at the same time. Since, I have retried programming both remotes many times with no success--the new one works, but the old one won't. The instructions were: 1) Locate switch under dash, behind fuse box; 2) Turn ignition switch on, but don't start engine; 3) Wait 5 seconds, set memory switch to SET position; 4) Press remote LOCK button; press second remote transmitter LOCK button; 5) Set memory switch to OFF; 6) Switch ignition OFF. 7) Confirm programming by locking and unlocking vehicle. Remote Key Programming Hyundai Forums Hyundai Forum
System operation Pressing remote control lock button locks vehicle and activates system Fig. 1 . Indicators flash once. Pressing remote control unlock button unlocks vehicle and deactivates system Fig. 1 . Indicators flash twice. Fig. 1 Synchronization When System malfunction. Remote control added or replaced. How Access alarm system control module located under driver's side lower fascia Fig. 2 . Set memory switch to SET position. Press remote control lock or unlock button. Set memory switch to OFF position. Confirm synchronization has been successful by locking and unlocking vehicle. Repeat procedure for second remote control. Synchronization can also be carried out using diagnostic equipment. NOTE: A maximum of 2 remote controls can be programmed. NOTE: If remote control fails, system can be deactivated as detailed in the owner's handbook.
i had a problem not unlike this in my santa fe 1.9td uk spec. my car had been sitting for a few months and when i returned to drive it again the same problem came to light. i also rep[lsaced the key fob. it could be one of two things. firstly the systen might neen re-set. if you disconnect the battery for 2 hours then attach ti again it might work. if this fails it might be the actuator in one of the doors. if it is faulty then it only semi closes the lock, but it then thinks that has to lock again. and locks the door. hope this helps. oscargilpin
Do the doors lock normally when using the manual switch on the dirver's door panel? If so, the problem is in the ETACS module. Here's the wiring diagram:
