Question about Microwave Ovens
Panasonic NN-E273S Still Operating With Door Open
I have a problem with my microwave. It seems to cooking fine, and when the timer ends, the microwave stops. The problem is, when I open the door, the microwave starts up inc light + turntable. Tried switching it off for a while, running through another cycle until the end of the timer, but still the same. (I know it should not be used with the door open, so turning it off as soon as I realise it does not stop.)
Chris
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
You can order other Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 16, 2008
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
Knocking noise in Panasonic Model NN-S969BA Manufactured 1999
open it and check screws. anything that vibrates will sooner or later loosen internal screws. maybe put a locking ring on it if u find it
ManualsLib Makes it easy to find manuals online
serach here for service manual .
Dec 10, 2017 | Panasonic NN-H275 Microwave Oven
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Panasonic microwave nn-6372awm memory codes
I HAVE A PANASONIC MICROWAVE,MODEL NN-6372AWM,SOMEONE WAS GOING TO USE IT AND I DON'T KNOW WHAT THEY PUNCHED,BUT IT NOW SAYS LOCK ON THE SCREEN,THE DOOR WILL OPEN BUT YOU CANNOT USE THE TIMER.HAVE HAD IT ABOUT 10 YEARS,WORKS FINE,LOST THE BOOK ON IT.CAN ANYONE TELL ME HOW TO UNLOCK IT.I AM SURE IT HAS A CODE.
Apr 21, 2010 | Panasonic Microwave Ovens
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
126 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
