Question about Maytag MES5570 Electric Kitchen Range
Element blew out, replaced, display not responding
The element on our Maytag blew out in a fiery display, and the oven was flashing and beeping. The breaker finally popped and I left it off till I replaced the element. Turning the breaker back on, the front display is not coming nor responding to button press.
The burners continue to work. I was unable to find a reset or onboard fuse. Any ideas area appreciated.
catriver
  • 878 Answers
SOURCE: oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Posted on Dec 16, 2006
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
SOURCE: frigidaire es300
you could have a power problem.. the stove will still work with half the power..like the burners on top will work. if thats not it. the wirers could be crossed or you may have a thermal cutout thats bad. but when the tco is bad broil and bake should not be working.. hope this helps
Posted on May 15, 2008
aborcass
  • 2651 Answers
SOURCE: replacing a radiant element on
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
Posted on May 24, 2008
  • 409 Answers
SOURCE: Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Posted on Sep 26, 2008
Replaced blown broiler element on Maytag oven mer5765qaq. Display did not come back on . stove top still works.
Good afternoon Schurtzfamil.
For a number of appliances, there can be recurring hiccups with displays after power is interrupted. Hopefully you unplugged the oven, or opened the breaker when you did the element replacement.
The manual can be downloaded here (
http://www.maytag.com/digitalassets/MER5765QAQ/Use%20and%20Care_EN.pdf ) There are a number of troubleshooting tips, including things like 'it's in Sabbath Mode, which is why the display isn't responding' that might help.
Lame as it may sound, the answer in many cases with the confused, power-interrupted display is to go back to the breaker, turn it off for a couple of minutes, then turn it back on. That will give it time for completely power down, and hopefully start normally this time. Hoping this helps! Good Luck!
Nov 18, 2015 | Maytag Kitchen Ranges
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
https://www.youtube.com/results?search_query=troubleshoot+Maytag+electric+oven+model+MER5552BAW
Feb 20, 2015 | Maytag Kitchen Ranges
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
After a "pop" - the oven no longer works
You should have thrown the breaker before moving the oven. The element likely shorted and blew the breaker. make sure the breaker is off. replace the element and plug it back in and reset the breaker.
Eric
Sep 22, 2009 | Ovens
Lower bake element in lower oven does not heat. What are common problems & can I get a fault code to display if I do not have one on the display, or does it mean none are present if not displayed? This...
Remove the lower bake element and test the ohms. If none replace the oven element and its fixed. The element is usually the problem and its fairly cheap to fix.
Nov 21, 2008 | Maytag Kitchen Ranges
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
hi there,
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Maytag MES5570 Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
