Question about NEC ND-3540A DVD RW Dual Layer Burner
Not working my computer recognises the drive in my computer but it wont play any disc at all even though my computer says this is working properly.
Try unplugging it plug it back in then goto add hardware wizard if you have xp and run the wizard if that doesnt work sounds like you need a new dvd burner
Posted on Sep 16, 2008
Acer aspire wont recognise cd roms but plays dvds
Have you checked your CD roms? Maybe they are already defective. Try running them in a CD player to see if they run smoothly.
Sometimes, the onboard driver update mechanism isn't that consistent with its result. I suggest that you use RadarSync to scan your computer to see if your drivers are updated.
RadarSync is a specialized PC Driver Update Software. You can scan your computer using the free version but if you want it to update the drivers then you can buy a year or two years subscription of the software to keep your drivers updated.
Let me know if you have any questions.
David
Feb 27, 2013 | Acer Aspire Z3731-UR21P
I have just installed the LG portable super multi drive and it wont recognise any audio cd that is in there???
Make sure the data cable and power cables are properly installed. Do any other discs work in the drive?
If you are using this on linux, you should be able to check /dev/ and make sure that the drive is mounting properly.
If it is mounting, then make sure you have all restricted packages installed so you can play audio. DId audio CDs work before?
Try using a different disc, like a movie or a program disc.
If no discs work, the drive may be defective.
If you like my solution, please vote for me.
Apr 09, 2011 | LG Electronics 16x DVD and 48x CD-ROM...
My acer 6920 wont recognise or play blu ray discs
The Acer 6920 does not come with a Blu Ray drive. The optical drive on it is a DVD drive. If you would like to play Blu Ray discs, then you'll have to buy a BD drive to play it.
Mar 24, 2011 | Computers & Internet
Disk drive will not read or play any disk / dvd?
You just might have a corrupted registry but it's easy to fix though just click on start - run - type regedit then In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters and or LowerFilters then delete both of them (sometimes only one of either of this shows up, but that's ok)
After deleting filters restart the computer and that should fix the problem.
Should you have any other questions just kindly leave a comment.
Cheers~
Jul 06, 2010 | Toshiba Satellite Pro L300 Notebook
Please help tycoon city new york wont work on my computrer!!!
it doesnt play it because your computer doesnt meet the requirements of your game in the back of the box says the required things and if you meet them
Feb 09, 2010 | Atari Tycoon City: New York for Windows
Dvd player not recognising any discs
Did You Try Taking off The Cover And Cleaning The lens With Rubbing ahocal
Jul 12, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
T will play music recognise computer disc but
I just used your fix by going in to the registry and deleted the filter keys rebooted and it worked thanks
Jul 09, 2009 | LG (GSA-4166B) (GSA4166BB) DVD RW Dual...
Advent 7113 - dvd/cd
hi
you need to check if the drive is Cd rom or a DVD rom if you try to play a DVD on a Cd rom it wont play, IF you are doing everything right then
try this
Go to my computer i mean right click on my computer and click on properties and then hardward tab >> and device manger>> and under DVD and cd right click on it and uninstall it and restart the system
Jun 08, 2008 | Computers & Internet
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
NEC ND-3540A DVD RW Dual Layer Burner Logo
61 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
