Question about Bosch Dishwashers
I have a Bosch SMU2042UC/14 dishwasher. The door will not latch. I have replaced the door latch and handle and still have the same problem. The dishwasher still works, will a little leaking, even though the door does not latch.
  • 5 more comments
  • joebixby Sep 12, 2008
    It's not the leaking I am concerned with as much as why the door will not latch properly.
    The dishwasher works with the door open.???
    It's stainless steel inside.
    I have replaced the latch and handle. It is fixed without any adjustment.
  • joebixby Sep 13, 2008
    It leaks because the door will not latch properly.
  • Anonymous Mar 17, 2014
    bosch dishwasher won't latch
  • Anonymous Mar 31, 2014
    Detailed instructions on how to replace the dishwasher handle on a Bosch SHU9952
  • 4,472 Answers
Is the latch adjustable? Have you checked your seals and your hinges? One of these has to be the cause. If you do not have the expertise to troubleshoot this problem yourself I would recommend a professional servicing the machine. If you need any other assistance let me know. If you have a moment to accept and rate my solution I would greatly appreciate it.
Thanks,
Lee
Posted on Sep 13, 2008
    Master:
  • 505 Answers
It it leaks replace the seals
Posted on Sep 12, 2008
  • 185 Answers
The door has problems When your dishwasher door has a problem, check these
Latch
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door.
Otherwise, the seal should compress over time.
Thank You
    President:
  • 1,952 Answers
I think steel may be corroded inside..so better check tat
    Genius:
  • 3,422 Answers
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  • 1 more comment
  • Priya darshan Sep 12, 2008
    The door latch pulls the door tightly
    closed to prevent water leakage around the door. It is also designed
    to prevent operation while the door is open. The door latch works
    in concert with the door switch to ensure
    that the door is tightly closed and latched.
    The door switch is a separate part
    from the door latch and is found inside the cabinet. The switch
    is off when the door is open. Depressing the switch closes the
    circuit and enables dishwasher operation. Closing the door does
    not depress the switch all the way. Only
    when the door is closed and latched, does the door fully depress
    the switch.
    If the door latch is not properly
    aligned it may not pull the door tightly closed and the door switch
    will not be fully depressed. Unless the switch is fully depressed
    the dishwasher will not operate.
    It is a simple matter to determine
    whether the door latch is the problem. Simply open the door, close
    the latch and select a cycle and depress the switch. Note that if the test is successful,
    with the door open, the dishwasher will operate and water may
    spray out. Make sure to first remove all tools from inside the dishwasher. Do
    not reach inside the dishwasher during the test. Now, inspect the cabinet where
    the door makes contact with it and locate the door switch. It
    may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must
    fully depress that switch. If the switch is recessed, then use
    a non-conductive object, such as a wooden pencil, to depress the
    switch.
    If the dishwasher begins to operate
    during this test, then you have isolated the problem. The door
    switch is not being fully depressed when the door is latched.
    There are three likely possibilities:
    1. The door latch is misaligned.
    2. The entire door is misaligned.
    3. The striker for the door switch is damaged
      or misaligned.
    To service the door latch, it may
    be necessary to access it in the control panel. Access varies
    by model; on some models you can remove just the control panel
    on others you must remove the interior or exterior panel of the
    door.
    Before removing the control or interior
    panel, look first for exposed screws that may allow you to adjust
    the latch or the strike plate. You may be able to loosen the screws
    and shift the latch on the door or the strike plate on the cabinet.
    It may require some trial and error, but you can loosen, adjust,
    tighten and test until it latches properly.
    I also gave a solution for your latch problem.Please accept my solution.
I am looking for a new or good condition used part #00150467 This is the 4 button selector switch for Bosch SMU2042UC/14 Dishwasher
try e-bay and type in the search box --4 button selector switch for bosch dishwasher
if there are any you will get pages of sales for new and second hand
try cruising all the appliance shops that service /repair dishwashers and see if any one has a part from a machine that suffered other failures
Sep 11, 2015 | Washing Machines
Where to buy timer motor for my bosch dishwasher SMU2042UC/14
I have had success finding appliance parts on Amazon of eBay, especially if you have a part number or Model number.
Nov 03, 2013 | Bosch Dishwashers
SHE33M Built-In Dishwasher handle broke off?
You have not put the full Enr, but from the bit you have added I assume you are in the states. I think you should be able to get parts from
http://www.searspartsdirect.com
Usually if the control panel breaks on this model, it is because you have the child lock activated on the door latch inadvertently and therefore have to force the door to get it open. This in turn puts stress on the panel which will eventually break. When you get the new panel ensure that you remove the child lock from the door latch. If you take off the front fascia panel and look at the door latch (centre top) you will see a yellow lever attached to it with a spring, just pop this off and you will immediately find that the door is much easier to open.
All the best.
Apr 18, 2013 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Need owners and/or service manual for Bosch dishwasher SMU2042UC/14
The specific model manual seems unavailable online but,click on the link below to get to the product support site and see the available manuals.
www.bosch-home.co.uk/customer-service/download-product-manuals.html
Hope this helps.Thanks!
Jan 07, 2012 | Dishwashers
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
633 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
