Question about Sharp 35VX-H2000 35 in. TV/VCR Combo
Sharp 27" VHS combo
The TV is probably 9 years old. The picture has gone and now there is a horizontal line in the middle of the screen. The sound works but no picture.
    President:
  • 3,130 Answers
Sounds like the vert output is defective. In this model i dont remember if its an IC or transistors. Also check the b+ resistor and cap comming off the flyback transformer as it will begin with the same parts seris #s that the vert output does. If your not an electronic troublkeshooter your gonna have to decide if you have gotten your moneys worth out of it and buy a new one or if you wanna keep patching it as It will continue to have falures in the next months to come or years to come as a 9 year old set is an old set in these parts. Now there are areas in the world where a new tv would take a years salary so peeps do have them repaired. Its all up to you. Good Luck
Posted on May 08, 2006
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
My TV picture begins flickering with a bunch horizontal lines across the screen, then the pictures comes back and is fine for a while and then it happens again. We ruled out the DVR box and cable...
You have a vertical IC that is in need of resoldering. And you can bet you have a few weak capacitors very close to this IC that need replaced. And while you are at it, check for a high voltage cap that may be weak in the horizontal section. This would be the next step in saving this TV. If you or a hobbiest can pull this board you could probably do the repair. Use extra caution when you do this. Or best yet find a TV Tech!
May 02, 2010 | Zenith C27A24T 27" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Horizontal line through the middle with sound. If you hit the side of the TV the picture will come back and then go away again.The TV is about 10 years old. Every now and then the picture will flash...
sounds like an intermittent problem. it could be a cold solder and it needs to be resolder it at the VERTICAL IC or transistor section , if your good with tools , you can do it yourself , otherwise take TV to a nearest repair shop, hope this helps , AJ
Jul 07, 2009 | JVC AV-27230 27" TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
