Question about GE JVM1860 Microwave Oven
GE JVM1860SF001 The vent door that attaches to the plastic cover is loose. Turns out the hinge on the plastic cover that the vent door conects to is broken. It is not obvious how the plastic cover is attached but I'm guessing it is just snapped in. How do I remove the plastic cover?... thanks
  • gpinker Sep 17, 2008
    I thought there may be screws on the top. The microwave must be removed from the underside of the cabinet to remove the screws since they are hidden by the cabinet. Thanks for you help. Great service
  • GE Master
  • 9,086 Answers
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
When removing the grill to replace the interior bulb I can't get the left side past the upper left door just above the hinge. PVM1970Sr1SS
sometimes you may have to remove all the screws on top to allow the cabinet metal to be a little more loose. then you'll just have to carefully, but forcefully, pull the grill loose from the left side first, then the other side. good luck.
Nov 28, 2015 | GE Microwave Ovens
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
Sep 12, 2014 | GE Microwave Ovens
The door on my GE advantium 120 fell off and I need to reattach it
take off the top vent cover , should be three screws ...hang the door provided nothing is broken off the door or the microwave.. after hanging put the vent cover back on. If your model has a little clip/postage size at the top hinge or if you think there is something missing at that location you may need that to keep the door from coming back off... It can be bought on line if your model needs it. some do and some don't if you found something near that area before the door fell off... then your model had one..
Nov 06, 2011 | GE Advantium 120 Convection/Microwave Oven
Clarification on microwave "cover" access
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-=-=]
Apr 26, 2010 | GE JVM1440 Microwave Oven
Door glass shattered
You really should contact GE customer service. There have been reports of this glass eplosion and they may take care of it for you.
GE Customer Service is here.
If they won't help, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 20, 2008 | GE JVM1860 Microwave Oven
How do I replace the door handle on microwave?
Once you follow the youtube instructions to remove the inside cover you are ready for the next step.
Remove the six small screws that are adjacent to the window. After this the front plastic is held in only by plastic clips to the metal door. The plastic clips and the screws together hold this together.
Remove the entire door by lifting up and move it to a flat service. If the top vent cover prevents this just remove the two screws on top of the microwave and pull the vent cover off.
With the door lying flat you can pull the plastic frame out on top and bottom and see how the clips work. Now just work you way around the frame until it separates.
Install handle and reassemble in reverse order.
Sep 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Apr 28, 2006 | GE JVM1330BW/WW Microwave Oven
GE JVM1860 Microwave Oven Logo
618 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
