Question about HP Photosmart R742 Digital Camera
WON'T POWER ON
MY CAMERA STOPPED TURNING ON FOR ME. I PLUG IT INTO THE COMPUTER SO IT SHOULD BE CHARGED AND I PUSH THE POWER BUTTON AND THE LIGHT BLINKS BLUE 3 TIMES AND DOES NOTHING. IF I HOLD THE BUTTON IT JUST KEEPS BLINKING BLUE. HELP ME!!
  • sowmya1306 Sep 12, 2008
    My camera wont turn on. It's a new piece. it got wet in the rain. when i turn it on red light comes. my camera model is samsung L74. plz help me.
  • kaetastical Oct 05, 2008
    My HP R742 does the same thing, it works when it's plugged into my PC with the USB cord but I don't understand why it won't work when it's not plugged in.
If it got wet let it dry out.or use a on blow dryer on cool only to help it but wait for a few days then try it again
Posted on Feb 04, 2011
Power button not working!!! This is different though....
This is a common problem that I run into. The battery will show charged when it really isn't. Take out the battery, plug the charger into the computer and try turning it on. If this works, you have a bad battery and it will need to be conditioned or replaced. If this doesn't work it could be a serious hardware issue.
Jun 25, 2013 | Dell Studio 1558 Notebook
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
My little buddy won't turn on, it's charged, plugged into computer. green light won't come on at all. I held the power button on for 10 -15 sec with no response.
I have 2 of these devices. Try using a cellular phone charger with the same plug at the end and plug it in. I have waited 5-10 minutes after doing this and they have come back to life and turn on. Maybe it will work for you.
Lewis
May 14, 2011 | Insignia GPS
I can't turn on the camera, even with a fully charged battery.
The battery contacts are like little springs, as the camera gets jostled these can stop making good contact. Open the battery case and try force holding the battery against the contacts (You may need to hold a piece of metal across the bottom of the battery as you push) Then see if the camera comes on.
If it does, you may have to stuff, pull, or rig the battery to fit more securely.
Mar 17, 2010 | Canon PowerShot SD950 IS Digital Camera
Won't turn on
look for reset near the battery compartment. should need a paper clip to push.
Jun 02, 2009 | Cameras
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Cmaera turn on/off
If you have used the camera a lot in that time frame then I would try a new battery first.
Jan 30, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Having trouble with turning it on
Try changing to rechargable batteries. I had exactly the same problem. I used recharable they run out so tried various types of alkaline batteries but the camera would not turn on. Getting the flashing green light. Charged the batteries put them back in and working again
Jan 19, 2008 | Samsung Digimax A402 Digital Camera
HP Photosmart R742 Digital Camera Logo
252 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
