Router connect in my office our two site are connected with tulip  vpn connectivitu ,i want to acess my router with internet it is possiable or not.
    Problem Solver:
  • 11 Answers
You can if you turn on remote management on the router.
Posted on Sep 13, 2008
I am trying to connect using Cisco VPN through my Motorola wireless router, but cannot connect. I check with my internet service provider and they do allow VPN. Our IT division has checked the...
The devices appear to be in functioning order. However, the connection network requires another computer on which signals are directed towards. The computer server on which network resources are acquirable is unavailable. For example, your devices can provide sevices to another computer if any were avialble. Usually an internet provider would allow acess to several computer with subscription. Consult an internet service provider, examples, at & t, T- mobile, Verizon, boost mobile, or consult any available at your local area. www.at&t.com, www.t-mobile.com, www.verizon.com, Goodluck
Jan 11, 2011 | Arris SURFboard SBG900 Wireless Router...
I used to connect VPN but suddenly DIR-655 is having probelm connecting to my office VPN. I can connect of any other web sites except VPN connection
Using VPN proxy http://www.bestcheapvpnservice.com/cheap-vpn-proxy/ will enable you to unblock websites and bypass blocking easly with simple software just pressing connect to open blocking and disconnect to block sites again
Jan 10, 2011 | D-Link Xtreme N DIR-655 Wireless Router
While using checkpoint VPN-1 SecureClient to connect to Safe@Office 500 device in office mode, i can't connect to server at the office site. The office mode is on a different subnet than lan so my vpn...
In the rules, you will need to create a new rule that allows your VPN subnets access to you office LAN, and then on your office network gateway, add a route for your VPN subnet pointing back to your checkpoint firewall.
Nov 08, 2010 | Check Point Safe@Office 500 Router...
Want to make a network connection between two office 800 meters.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Mar 03, 2009 | D-Link (DIR-130) Router
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
New firmware..now problems
Does your office require VPN passthru to be enabled on the router? Did the firmware update reset the VPN passthru setting blocking your access?
Dec 07, 2007 | D-Link Express EtherNetwork DI-604 Router
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
