Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Installing new inlet valve
I need help on installing new inlet valve for my kitchen aid refridgerater ice maker.
(1) How do I remove the existing plastic tubing-Does it just get pulled out?
(2) Do I then just push the plastic tubing into the new inlet valves?
I'm a little confused do the 3 rotating plastic pieces that are inserted into the part where the tubing gets inserted need to be removed prior to inserting tubing?
Should I unplug unit prior to installing new part?
I know what to do with the 2 electrical connectors.
Thank you
Mike
  • 120 Answers
Mike most water valves not are easy to repl the dispencer li and ice maker line are just push in all the way and they lock in place and to remove the all you do is push the ring around and they get relase. now the main line that supplies water that one you have to screw right you need new connectors.
Posted on Oct 15, 2008
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kitchen Aid side by side ksra2scnss00 ice maker not working....Water dispenser is working fine
The simple solution for your refrigerator is to replace dual water control valve.For example if your model was the IKSCS25INSS the replacement part would be the=> W10247725 Water Inlet Valve It also could be your ice maker itself so if the ice slots ar empty fill with tap water and allow to freeze. If the ice freezes and drops into the ice bucket and then does not refill with water then replace the water control valve. If not then it nis possible the ice maker is defective and will need replaced.Not knowing the correct model number I think it wouls better that you call Repair Clinic at 1-800-269-2609 and they will be happy to help you find the correct ice maker. 2198597 Ice Maker Assembly Should you have any questions I will be here to assist you, Thank You, Sea Breeze
believe you have your model number wrong so I will give you this link=> product literature search
Oct 03, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid KSRG25FKSS05 water and ice maker have stopped working. I have tried numerous things. How should I fix this?
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jan 07, 2011 | Refrigerators
Icemaker is not working in my kitchen aid superba
Hi, If your ice maker has stopped working then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken.
All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | KitchenAid Refrigerators
Kitchen aid ice maker water overflow issue
it's gonna be either the water valve or the gear shaft in the ice maker. replacement ice maker $130.00 water valve $40.00. gear only comes in with module $90.00. low water pressure from plugged water filter can cause this or if a reverse osmosis system is hooked to it. 40 pounds or more is reccomened for the valve to work properly
Dec 09, 2009 | KitchenAid Refrigerators
Water not working but ice does - kitchen aid superba
When you activate the switch, do you hear the inlet valve buzzing? If you do, check the container or tubing in the fresh food side and make sure it is not frozen. If you do not hear the valve buzzing, chech the valve. If it appears to be ok, then you will need to check the switch inside the door control panel.
Please let me know if I can help further.
Thanks
Vic
May 20, 2009 | KitchenAid KSCS25FKSS Side by Side...
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
Jan 26, 2009 | KitchenAid Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
102 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
