Akai PTH5498 54 in. Rear Projection HDTV-Ready Television
Problem for Akai PTH5498 54 in. Rear Projection HDTV-Ready Television
Shadowing
By milkweed on May 08, 2006
All images have a blue shadow.
Same Problem
Dec 20, 2008
-   Can anyone help please, I have blue shadowing just to the right of the picture, and seems like your looking at 3d film without the 3d glasses on, sounds strange, but thats actually the best description i can give.
Thanks,
Gene
-   genieusa
Nov 30, 2008
-   i have blue shadow just to the right of the actual pitcher-   neil84
May 25, 2008
-   Blue shadowing--Is is a problem I can fix? -   Guest
Best Solution
posted on May 09, 2006
Helpful)
techman
Rank: Guru
Rating: 86%, 7632 votes
Have you tryed to adjust the on board convergence yet?? it sounds like the blue horizontal could have shifted. Put the aset in test mode and adj befopre taking set to servicer. Good luck.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3608 votes
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
Looks like a picture tube problem.
Try to reduce the contrast, maybe it will be better.
Look into the three tubes while the TV is running, and observe the
picture quality of the three. If the red and green are crisper and clearer, and the blue's all hazy from bacteria growing in the coolant, then the fluid needs to be replaced. The CRTs of the colors that seem hazy need to be removed from the light box to be
serviced. The coolant needs to be drained, the CRT assemblies
disassembled and totally scrubbed clean and refilled, then reinstalled and converged. If the coolant is
clear, it can be a weak CRT.
Also the convergence STK ships might need to be replaced, and the soldering checked.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Akai PTH5498 54 in. Rear
Questions and Unsolved Problems for Akai PTH5498 54 in. Rear
Do you recommend Akai PTH5498 54 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a series of flickering horizontal lines that have suddenly appeared towards the bottom of the... (More)
Answer
Akai (PTH5498) 54" rear projection TV with red and green ghosting and large curve in the... (More)
Answer
I have an akai rear projection big screen tv that has blue shadows on everything. When the auto... (More)
Answer
how do you adjust red convergence in a akai 54" model pth5498 tv?
Answer
How do you work the convergance system? What are you supposed to do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Akai PTH5498 54 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
