Question about ViewSonic P225f (Beige) 22" CRT Monitor
Viewsonic P225f CRT - clicking "short circuit" sound, shrinks and expands
WARNING: This is a fairly obscure problem.
I have a Viewsonic P225f CRT monitor, the 22" version. The model number is VCDTS22074-1M. The manufacture date was April 2002.
Conditions: The monitor is on. At any resolution, and any vertical refresh rate, this problem is currently present. It is somewhat sporadic, that is, the monitor can go for a while without having this happen to it. Through my own research, it may be caused by "dirty" electricity(I am currently renting in a very old house).
Possible Related Problem:
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-09/msg01772.html
Problem: Basically, when the monitor is on, I hear a distinct "sparking" or "short-circuiting" sound. The CRT continually turns/clicks and shrinks and expands at a very irregular, almost random, rate. It does it even when turning on or off, now, as well. Sometimes it displays a clean, perfect picture for 10 minutes before doing it once or twice, and then it doesn't happen again for 20 minutes. Other times, like right now, it keeps clicking every second or two.
It is very possible that this is due to dust build-up in within the monitor itself, as I purchased this from a man who stored it in his garage for some time. I will try the air compressor and edit this post to see if that fixes my problem.
If you have further knowledge about CRT tech in general, you might know what is going on here. Please fill me in! Thank you.
  • 1 more comment
  • p1agu3
    p1agu3 Sep 15, 2008
    Hmm. Well, I thoroughly cleaned out the inside of my CRT, and it's still doing the same thing. Dust is likely not causing the issue. After doing more reading, etc, I still don't really have a clue what could be doing this.
    I looked for bad solder joints, but I didn't really see any. It's definitely coming from the back of the monitor, though. I'd just love to see a repair manual for CRT monitors so I can troubleshoot properly. Either way, I'll keep commenting and documenting my findings.
  • p1agu3
    p1agu3 Oct 14, 2008
    It looks like this problem could be due to "dirty" power coming in to the monitor. I've ordered an automatic voltage regulator that works in the same way as a powerstrip; hopefully this will eliminate my problems. I'll post again with an update when I figure it out!
  • p1agu3
    p1agu3 Jan 30, 2009
    UPDATE: I dusted the monitor out and bought an Auto Voltage Regulator from Newegg. Neither fixed the problems, though they seemed to happen less often with the clean power I was sending to the unit.
    It still had the problems, however, and I assumed it was still a problem with the power in this house, so I sold it for $75.
    The person who bought it from me smelled burning and heard a sickening crunch a few days ago when it finally went.
    Problem was never solved...good luck to others with similar frustrations.
    Sergeant:
  • 300 Answers
Just on a whim I'd say open er up and dust it out , and look for bad solder joints.
That means get out your soldering gun and have a look around the board.
what you described is "intermitant failure" sparking sounds , that prety much indicates a bad solder joint some place , not dirty power , if you suspect dirty power , you can buy a little UPS voltage regulator 6 outlet , those little things can really do the trick when it comes to dirty power because
they can regulate the voltage ALMOST like a full blown UPS backup unit without the battery.
You sound like a smart person who understands power has to be clean , and you seem to understand that intermitant failure is like performing a ( shock test ) where you actually tap on the
device to see if something is loose.
if something IS loose thats like saying open circuit , so that means get in there and have a look for a bad solder joint , I'll bet dollars to donuts it's a bad solder joint at the plug of the monitor , thats because thats where the point of contact is with the power cable , and we tend to wiggle the power cables on our monitors which causes arcing and sparking , if you get my meaning.
I have every confidence you can trouble shoot this problem with just the simple things I've told you.
Go get em tiger.
Shalom >:D<
Posted on Sep 12, 2008
RCA 20F424T - 20" CRT TV Screen shrinks and expands - may or may not correct itself after the TV warms up. Also the TV is blurry
Fault with the main power supply regulator section circuit. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 13, 2014 | Televison & Video
I have 99 oldsmobile Alero. When I turn it on the oil , battery , seatbelt light turn on. But when I turn the engine on the gauges don't work. But when the weathers hot outside the gauges turn on. Any...
SOUND LIKE SHORT IN GAUGES. HEAT WILL CAUSE SHORT TO WORK.HEAT FROM THE SUN WILL CAUSE PLASTIC EXPAND WHEN PLASTIC SHRINK BACK IT WILL CRACK.IF CLUSTER GAUGE HAS A CRACK IN THE CIRCUIT BOARD HEAT WILL CAUSE PARTS EXPAND ENOUGH TO WORK AGAIN.
Aug 22, 2011 | 1999 Oldsmobile Alero
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Voltage / connection
Refresh rate cannot hurt a monitor. Besides, on modern monitors, if the mode is not supported the monitor will just shut down.
One of the vertical output transistors has failed. This is a common failure on cheap monitors.
Jul 25, 2009 | ViewSonic P225f (Beige) 22" CRT Monitor
99 new beetle- warning chimes not working
Have you checked the fuse box, it may be on an obscure circuit. check each and every fuse closely.
Hope this is of some help.
Apr 20, 2009 | 2001 Volkswagen Beetle
INEED NO. OF OUTPUT HORIZONTAL LINE TRANSISTOR
If you mean 'flyback' or 'horizontal output transformer' and have the part number available, try one of the sources here:
Flyback links
If you do not have the number you may have to search Viewsonic's website to loacte it.
Warning; the number of suppliers for CRT monitor parts is shrinking rapidly, my best supplier, ICM in California is long gone.
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
Picture shrinks and expands
Not positive but this sounds like the impending failure of a specific power supply, namely an output providing deflection voltage to the CRTs. This may be simply a circuit on the main supply or could be a separate supply on a different board than the main supply.
If it is not affecting brightness and contrast, it isn't likely to be the primary supply that is failing. I'm pretty sure it will continue to degrade.
Oct 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 51pw9363 51in
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 25, 2007 | Philips 9P6040C 60" Rear Projection...
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
ViewSonic P225f (Beige) 22" CRT Monitor Logo
424 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
