Question about Canon imageCLASS® MF4150 All-In-One Laser Printer
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
We just installed a Canon imageCLASS MF4150. The problems is the fax is picking up all calls that come in on that line and are not distinguishin between voice or fax.
Here's how we have our telephone system set up. We have two lines and a two lined answering machine. If a call comes in on line 1 and noone picks it up, the answering machine will pick it up and any messages recieved go into the line 1 mailbox. If you call line 1 and it is busy, the call rolls over to line 2 and if it goes unanswered, line 2 of the answering machine will then take a message. Line 2 is primarily a fax line, but occassionally we do take calls on that line if line 1 is occuppied. We need to continue with this type of setup.
With our old fax machine, the machine was able to distinguish whether calls on line 2 were voice or not, and would automatically pick up fax calls.
I've followed the manual and have tried the - this ended up having the fax going to the answering machine. I should mention, the answering machine is setup in a different part of the building. When I tried the setting, the fax machine automatically picked up every call. I do have an extension phone plugged into, but really we don't need an extension phone on the fax machine. Same scenario with .
Any ideas? Thanks in advance :0)
  • spshled Dec 02, 2008
    i have a custom ring setup for the fax, how do you set the fax up so it will only pickup the custom ring tone and not all calls
  • Anonymous Feb 22, 2009
    same problem
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Posted on Sep 13, 2008
MF4150-All Panel lights remain ON and no response with any other button on display and Start and Stop/Reset button light also remains ON.
Support ' Support Laser Printers - imageCLASS ... - Canon
https://www.usa.canon.com/.../printers/...laser-printers-imagec...
Canon Inc.The imageCLASS MF8380Cdw delivers fast and accurate printing in approximately 14.3 seconds with Canon's Quick First Print Technology. Multi-page ...Missing: mf4150 ‎panel ‎remain ‎response
Amazon.com: Customer Questions & Answers
www.amazon.com/ask/questions/asin/B000J4J70Q
Amazon.com, Inc.Canon imageCLASS MF4150 Laser Duplex P/s/c/f 21PPM Adf ... make a two side
Feb 05, 2016 | Canon imageCLASS MF4150 All-In-One Laser...
How can I install my printer (Canon imageclass mf4150) without the cd and no needing fax capability? I tried installing manually but won't work any advice?
You can download the drivers for Canon MF4150 from Official Canon Site. Click here and go to 'Drivers & Downloads' - Select the Operating System you have on your PC (e.g. Windows XP) and you will get the drivers and software for you printer.
GoodLuck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
Dec 10, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My Canon MFP4150 cannot send international faxes. I keep getting error message 0091 : error during tx. Please advise a solution.
make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Jan 20, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Fax recipt problems for Canon MF4150
My faxing not gothrough,what shold I do now?
Mf4150
Aug 29, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF4150 Fax Problem
on the settings, it needs to be set for a certain number of rings, and also on auto receive
Jun 14, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
My fax keeps saying no anwser how do i fix this i need HELP!!
call the number you are faxing from a regular phone. If you get fax tones you need to check you fax line. Plug a non-digital phone into the fax line and place a call. Try that and let me know the results
Dec 13, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
Canon imageCLASS® MF4150 All-In-One Laser Printer Logo
296 people viewed this question
old marine
old marine
