This could either be an inverter issue, or a backlight issue. Lamp replacement varies from very easy, seconds, to impossible without returning the entire panel to a service depot. There are some other possibilities (cables, motherboard problems controlling the backlight) but they are RARE. Inverters are relatively cheap (they are not "cheap", but they are still 80% less than a new LCD panel and 75% less than replacement backlight IF you could get it replaced). A new inverter is likely to be in the $50-$75 range. Any difference when working with batteries as opposed to AC? If so then it could be related to a power saving setting. But if your screen is completely dark, only visible with a light flashed at the screen, then that's not it. Good luck post a comment for the result
