Question about Dell Latitude C400 Notebook
C400 Display problem related to Flash player
I have a Dell C400 laptop I got used from the company I am working for. It worked fine (at my knowledge) before I got it but I decided to format the HDD for a clean start with clean OS update. I have 512 MB of RAM, Intel® Pentium® III Mobile 1200MHz and Intel ® 82830M Graphics Controller
I installed Windows XP professional with all necessary parts and updates. I got all available updates from Dell Support including BIOS version A12. No other applications just a clean Windows.
Everything is running perfectly until I installed adobe Flash player plug-in.
After installing the flash player, browsing is terribly slow and if I run a flash video the computer halts intensely and the CPU usage up to 90%(IE) . After running webpage with Flash all video based or graphical process uses high CPU power and are working really slow.
If I uninstall the Flash player and reboot, the computer starts working normally again.
I am a computer technician myself and I really think I have tried everything, for example:
- Try several versions of flash player (7, 8, 9.0.47, 9.0.115, 9.0.124)
- Try different versions of the display drivers (the newest driver packages from both Intel support and dell support)
- Try different types of browsers and browser plug-ins (IE6, IE7, Firefox, Goggle Chrome)
- Tried the Hardware Acceleration troubleshoot in the Display properties.
None of these have lead to any success in finding a solution.
I even learned that the Intel ® 82830M Graphics Controller appears as two adapter in the Devise Manager (Intel says its suppose to be like that) and if I disable one of them (the one market as function 1) the flash player works fine and I can watch a flash video for about two minutes and then the computer shuts down without any warning or security log or anything.
All my testing have lead me to the conclusion that this must be some sort of a conflict between the Flash player plug-in and the video-controller (driver or VBIOS). It is like the Flash player uses up all video memory and it does not get dumped again until I reboot the computer.
I have been searching the Web for any clue of what can be wrong without luck, I have read what there is on bouth the Dell Support, Adobe Support and Intel Support with out luck
Yes I have considered using the computer without the Flash player plug-in, but that is getting more and more difficult for there are so many websites out there using Flash.
Can anyone help, this have been hunting me for weeks now
Thanks in advanced
Tumi
  • Tumi_Iceland Sep 15, 2008
    I am a afraid this did not help.
    I downloaded and installed the Intel® Chipset Software Installation Utility and then reinstalled the display drivers provided by Dell support.
    If I now open a flash video from the web (YouTube for instance) it runs smoothly for about one minute and the computer shuts down.
    If I only open a website that uses flash, it will run smoothly for few minutes and then the computer slows down. After that the computer is really slow until rebooted.
    The Intel 830M uses a dynamic memory allocation and I wonder if that has something to do with this and if so, is it possible (and then how to) configure the size and location of that memory and if it is possible to monitor the memory usage of the video controller?
  • Krish30 Mar 10, 2009
    I have the exact same problem. Did you solve the problem tumi?
    Champion:
  • 208 Answers
Update intel graphics driver 830M and intel chipset also
Posted on Sep 12, 2008
My Del Latitude C400 screen will not work how do i plug in an external monitor
connect to external monitor with 15pin connector. and there is one function key is there with symbol of monitor. at the time of booting presss that key external display will come
Jun 16, 2010 | Dell Latitude C400 Notebook
I upgraded my laptop Dell C400 to windows XP but now can not change display resolution. Only option is 640x480. Went to http://support.dell.com/support/download. and got a bunch of drivers for C400;...
Please use following link for drivers :
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_P3_C400&os=WW1&osl=en&catid=&impid=
You just download it and install.
Regards
Ashly
Feb 02, 2010 | Dell Latitude C400 Notebook
The usb of my dell latitude c400 notebook is malfunctioning
Unfortunately, I have seen this many times. One of the major problems with the C400 model was the USB port failing. I have had many of them replaced under warranty, and I have repaired some. The USB port breaks loose from the mother board and stops working. It is possible to SOMETIMES disassemble the laptop enough to get to the port and re-solder the USB port connections. But is is a slow process for experienced people. And it does not work all of the time. i know that this is not the answer that you wanted.
Good luck with it.
~ Spoem
Mar 18, 2009 | Dell Latitude C400 Notebook
Cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
Oct 22, 2008 | Dell Latitude C400 Notebook
Dell latitude c400 sound probel
First check the sound settings, it could just need adjusting. If the settings are correct, then you have a driver glitch, uninstall the sound drivers from the device manager, then reboot. The machine will find the sound card and reinstall the drivers automatically. Then check Dell's support site for updated sound drivers.
Aug 13, 2008 | Dell Latitude C400 Notebook
Ineed assitance on my Dell C400
install display drivers it will solve, download drivers from dell.com...
May 02, 2008 | Dell Latitude C400 Notebook
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
324 people viewed this question
Alun Cox
