LG WF T1022TP Drain Problem
When it completes the wash cycle, it stops and will not advance to drain and rinse. This happen on occations, but is getting worse
The problem has been traced to the water pump that does not turn on every occation that the power is applied. The pump just vibrates. Quess that it is worn out, and needs to be replaced.
Posted on Sep 13, 2008
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
LG WF-T1022TP Fuzzy Logic
hi my name is joyce
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
joyce
Feb 06, 2009 | LG WFT1071TP Top Load Washer
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Apr 22, 2008 | Washing Machines
Problem in my washing Machine
If your timer is stopping at the drain cycler (before the rinse) check the LID SWITCH. Most washers will not drain or continue the cycle if this switch is not closed. Open the lid and look for an opening in the housing were the lid sits. try depressing it manually while the timer is at the drain cycle.
Jul 18, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
