Question about Panasonic NV-DS60 Mini DV Digital Camcorder
Panasonic DV mini camcorder error message
When I turn the camcorder on the message,"dew detected eject tape" appears. How can I resolve this issue? I took it to a camera shop and they advised me to throw it away and tried to sell me a $500 camcorder. Please advise...
  • kathy7795 Sep 12, 2008
    I JUST RESOLVED THE PROBLEM WITH ANOTHER SITE ONLINE. REMOVE BATTERY, HIT BOTTOM OF CAMCORDER WITH PALM OF HAND (JUST BELOW BATTERY COMPARTMENT). VOILLA...IT WORKS!
  • 4,234 Answers
Inside is a sensor that detects moisture. If there is dew inside the unit, the tape will adhere to the head and create all kinds of problems. This sensor is there to to prevent problems. That being said, the repair for this could be as simple as ejecting the tape leaving the unit open and letting it dry out. It could also be a bad sensor. In the case of the sensor, the parts cost would be in the $10-$20 range. Add in the local labor rate ($175 here in Mass) and you have the total repair cost. While this is not the easiest repair because of its size, anyone that works on camcorders will find it straightforward.
Dan
Posted on Sep 12, 2008
  • ABRsvcs Sep 12, 2008
    Please note that this will be a temporary solution. If a slight tapping "fixes" the problem, there is a bad connection inside with the dew sensor that will show up again. This should be repaired. If you bring hte camera to a service center and ask that the dew sensor be "re-soldered", the charge should be minimal.
    Dan
Camcorder panasonic displays dew detect in red
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
Jan 14, 2009 | Panasonic PV-GS39 Mini DV Digital...
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
Dew detection
try getting a head cleaner for the camera and see if that works. If not then moisture mas seeped into the cameras circuits and caused a short circuit. seems like the only way to fix it, is to have it sent back to the manufacturer for repair.
Jun 30, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
Feb 24, 2008 | Panasonic PV-GS39 Mini DV Digital...
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Where is the reset button on this camcorder, Panasonic PV-DV203 Mini Dv? I can't find it. Also what do it do about everytime i turn the camers on it says "DEW DETECTED EJECT TAPE" There is no...
I haven't used mine for over 2 years because of the mildew detected warning and not being able to find anyone to fix it for me. I just found this on the internet and am going to try it when my battery charges. Seems this is a common error for these palmcorders... good luck! "When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew."
Jan 05, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected error signal
Good Luck,
Luwangula
Nov 11, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
230 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
