Question about Danby DWM99W Top Load Washer
Danby add water cycle, water being pumped out.
Thanks so much for your reply to my wife yesterday in regards to our Danby washing machine problem which is pumping water out occasionaly when water is being added to the agitator drum. Further to the problem identifed yesterday, when water is being added on any cycle and the drum gets about one third full it will sometimes start to drain. If the power is disconnected while it is draining the unit still drains until it is empty and you can hear air enter the system and the draining stops. I am wondering if some type of sypioning is happening. The washing machine drain is connected to the drainage pipe which is the same diameter as the washing machine outlet drain( 3/4 "). The connection between the washing machine drain and the drainage pipe is air tight. I would think that the pump would have to start at some point, say one third full?, during the add water cycle to start the water draining to start a sypioning effect.
I have checked for a solenoid valve and can not seem to find one. I have removed the drainage pipe where it leaves the pump assembly. With a flashlight I can see what looks like plastic impellor blades inside the discharge suide of the pump assembly. I can not readily identify a drainage valve or a seperate solenoid. The drainage pump motor seems to be a sealed unit which locks into place with two plastic tabs and has two external magnetic arms which apperar to drive the pump armature which is enclosed in the plastic pump assembly, if this makes any sense. I have removed the pump unit and reinstalled and it is completly sealed and has no exposed wire connections where I can connect a meter. I guess I could strip some insulation off the wiring but I am hesitant at this point.
I would really appreciate any additional advice that you may be able to provide to help fix this problem.
Regards,
Dirty Clothes in the Yukon
    Scholar:
  • 141 Answers
The pump acts as the drain valve. It sounds like the pump check valve is not working and you will probably have to replace the entire pump. The pump is fairly easy to replace.
Verify that the outlet from the pump goes directly to the drain hose. If so, the only other thing you can do is remove the drain pump and disassemble it to see if something is stuck in there or something. However, this is a more advanced procedure so I would recommend against it. Replace the pump.
Posted on Sep 12, 2008
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
Danby front load washer Will not spin motor runs
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Jan 25, 2009 | Danby DWM5500 Front Load Washer
Drainage system for front load washer
Take bottom off machine; pump is right there. You can investigate from there. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | GE Washing Machines
Danby DWM5500W Washer
I had it also, Swap your hoses. I had my hot and cold on wrong.
Sep 13, 2008 | Danby DWM5500W Front Load Washer
Rinse cycle of our Danby Portable washing machine
Find the drain solenoid valve and see if it is stuck open. It should be near the drain outlet. Measure the power at the drain solenoid. It should be 0 volts when the washer is filling. If there is power there (AC voltage), then there is something wrong with the control board, this is unlikely. I suspect the solenoid valve has seized in the open position. Manually advance the wash cycle to drain or spin. The solenoid should click when it opens. If it buzzes, then it is seized. The best thing is to watch and listen as you advance the cycle and see if you can verify what the valve on the solenoid is actually doing. I suspect you may want to replace this solenoid.
Sep 11, 2008 | Danby Washing Machines
Series of clicks..then dead
The load size adjustment only changes the level of water used, this could not cause a fault,sounds like a faulty rinse valve or depending on model a faulty or blocked pump. Regards Engineer
Feb 27, 2007 | Maytag Performa PAV2200
Danby DWM99W Top Load Washer Logo
146 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
