Analog copier skewness in copies
If i make a copy of a grid, then the longitudinal lines are ok but the transversal lines (accross the platen) are not perdendicular, resulting in a skewed copy. The skewness is about 2mm across 200mm
OK Thanks for the tip. However, discovered and fixed the problem. While refitting glass, discovered wobble, arising from twisted chassis, arising from sagging corner of countertop on which the machine was standing. Once the machine was placed on level surface and corner propped to over-compensate, copies were fixed.
Posted on Oct 06, 2008
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1-it could come from the ADF - if makingfrom the doc feeder adjust screws in rear or ADF
2-the scanner adjust the scanner - turn off machine remove glass and adjust
3-if making from feeder the glass itself may be too dry, spray WD40 and wipe leaving a smooth surface.
Posted on Sep 12, 2008
I have canon Ir2270 machine. In this Computer print is ok but when copy to copy then large vertical white line is coming in the side.please help.
Him are you using the upper feeder or platen glass? . If copies are ok in platen glass . There is dirty in the feeder reading glass
Feb 05, 2018 | Canon Office Equipment & Supplies
Black lines across copy when using Document Feeder.
Many people ask this same question over and over again. "I get black thin line (s) when using document feeder. If my original is on the platen glass copy is OK."
Well, in most copiers, be it Xerox or Canon or Sharp there is same principle in use. When document is moving it is exposured (copied) by a steady non-moving exposure lamp. If there is any dirt or even a dust particle on the narrow platen glass it will print out as a line.
Most people don't understand this principle and they say "I 've cleaned the platen glass".OK, they have cleaned the BIG glass, but the glass is the narrow one next to the big one. Very often there is glue or white correction lacquer on the platen which of course adheres more dirt.
You may use even the strongest solvents to get dirt off the glass. Remember, it is made of glass and won't get hurt even if you use thinner or nail polish remover.
This tip applies also on fax machines. The receiving end may call back and say "your fax has a lot of lines across the copy".
on Sep 08, 2010 | Office Equipment & Supplies
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
Black colour lines in xerox only
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Jan 30, 2015 | Canon ImageRunner 4570 | IR4570 |
Photocopier producing skewed finished copies. What can be the problem?
If the image is skewed on your paper, you have a registration bushing broken.
If the image is OK on the paper, look for a piece of paper or a little thing in the way of copy
Jun 27, 2011 | Ricoh Aficio MP 1600L Black and White...
When I fax it copies a black line is on the page. And when I copy from the top part it copies a black line. How can I fix that?
are you getting black lined copies while you are trying to send a fax or black lined images are obtained at the receiving end. Is there any problems while copying from platen glass. if it's ok, then check if there is any thing on the stream reading glass (the small sized glass plate meant for ADF) & clean it.
Apr 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Make on copy in the dockfeeder,and one copy on the platen glass.If you only have a line on the one copy make by the dockfeeder,the small glass next to the platen glass is dirty.Clean with spirits.
Let me know.
Oct 31, 2008 | Canon imageRUNNER 400S Copier
Ricoh FT4522 Analog Copy machine
- Clean the glass of your Machine from inside to out-side copies
- Check Cleaning blade if they have damage or try to clean before you replace the parts.
- Check Drum if they have damage.
Sep 21, 2008 | Office Equipment & Supplies
82 people viewed this question
