Question about Intermec CK30
Green light stuck on.
Green light stays on above the tab key. Unable to perform a cold or warm boot. Tried to reinstall the OS but the ck30 is unresponsive.
This sounds like you forced a cold reboot. You do not mention pressing "reset" under the battery, which does the same thing.
Posted on Jul 17, 2010
Left the ck30 powered off and removed the battery. Replaced the battery with a fully charged one. After a couple hours rebooted the ck30 and it booted normally. My ck30 was tied to the AS400 system. I think this may have been a factor with this issue.
Posted on Sep 15, 2008
Mc9100: how do I reboot it?
Contact Motorola Solutions for assistance.
portal motorolasolutions com
Mark
Motorola Mobility Support
Jun 13, 2014 | Motorola MC9190-G Handheld Mobile Computer
Hoe to reboot pdt6840 scan gun
Warm Boot:
- Press the "PWR" button to turn the unit off.
- Press the "4" and "5" keys at the same time.
- While still pressing the "4" and "5" keys press and release the "PWR' button again.
- Release the "4" and "5" button.
- The PDT6846 should perform a warm reboot.
Cold Boot:
- Press the "B", "D" and "A" keys at the same time.
- While still pressing the "B", "D" and "A" keys press and release the "PWR' button again.
- Release the "B", "D" and "A" button.
- The PDT6846 should perform a cold boot.
May 03, 2012 | Symbol PDT6842-NIS632EU Portable Data...
How to factory default Mc75 device
Resetting the MC75
There are two reset functions, warm boot and cold boot. A warm boot restarts the MC75 by closing all running
programs. A cold boot also restarts the MC75, and also resets the clock. Data saved in flash memory or a memory
card is not lost.
If the MC75 is not functioning properly, perform a warm boot first. If the MC75 still does not respond, perform a cold
boot.
Performing a Warm Boot
Hold down the Power button for approximately five seconds. As soon as the MC75 starts to boot release the
Power button.
Performing a Cold Boot
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Motorola MC75
What is the cause of a 51.2M error on a HPLJ4600 color printer
Hello
According to HP following is the remedy for this error
  1. Turn the printer off, and turn it on again.
  2. Remove the surge protector or Uninterruptible Power Supply (UPS) and connect the printer directly to a power source.
  3. Try a different power cord.
  4. Try a different electrical circuit or outlet.
  5. Inspect the fuser for media or damage, and reseat the fuser.
    1. Open the top cover.
    2. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
    3. Unscrew two blue knobs located on each side above the control panel.
    4. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
    5. Reinstall the fuser.
  6. Perform a cold reset on the printer.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green c00224695.jpg (Select) button.
    4. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  7. If this message persists, contact an HP-authorized service or support provider. Hope it helps, if so do rate the solution
Dec 24, 2010 | HP LaserJet 4600 Printer
Could you tell me what has to be done when the only item appearing on the screen is MC70?
Resetting the EDA
There are two reset functions, warm boot and cold boot. A warm boot restarts the EDA by closing all running
programs. A cold boot also restarts the EDA, and also resets the clock. Data saved in flash memory or a memory card is not lost.
Perform a warm boot first. If the EDA still does not respond, perform a cold boot.
Performing a Warm Boot - Soft reset
Hold down the Power button for approximately five seconds. As soon as the EDA starts to boot release the Power button.
Performing a Cold Boot - Hard reset
Dec 03, 2010 | Zebra Symbol MC70 HandHeld Mobile Computer...
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
I just replaced the fuser kit with a brand new NON-refurbished fuser, and it is continually giving me the 50.4 error message and telling me to restart the power and recycle the power. What now?
Hi
Thanks for using FixYa. Error 50.4 means A faulty fuser error has occurred. There may be a problem with the printer's fuser, or inadequate external or internal power supply/line voltage.
a. Open the top cover.
b. Locate the green square tab on the right of the fuser flap and lift it to inspect the fuser roller for media or damage.
c. Unscrew two blue knobs located on each side above the control panel.
d. Lift the fuser by grasping the fuser housing above the green arrow on the left and right.
e. Reinstall the fuser.
a. Turn on the printer.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green (Select) button.
d. Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady.
f. The control panel will display SELECT LANGUAGE .
g. Press (Down Arrow) button once. The control panel will display COLD RESET .
h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Please see this link for more detailed info--
HP Color LaserJet 4600dn Printer error 50.4 Details
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 20, 2009 | HP LaserJet 4600dn Color Printer
Intermec CK30 Won't Display Desktop
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Nov 27, 2008 | Intermec CK30
Acer5630 unable to boot
remove your battery and on your system other wise reinstall the os
Mar 06, 2008 | Acer Aspire 3003LCi Notebook
Intermec CK30 Logo
1,205 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
