Question about Acer Computers & Internet
I cannot put my Vista computer into "Sleep" mode, and return with the Broadband working. My computer seems to change the Broadband setting to Local after the "Sleep" mode is employed. Can you help please?
  • irismorgan Sep 12, 2008
    Thank you Jelly Bean A but could you explain how to enable BIOS. I'm a novice with the Vista computer, and am finding it very time consuming when something goes wrong. Thanks.
    Iris Morgan
  • 4 Answers
Have you enabled in BIOS?Example for the keyboard or mouse to wake the PC up?
Posted on Sep 12, 2008
How to turn off sleep mode in Windows Vista
try going into your control panel and look for your display icon,see if you can do it from there.
Feb 08, 2014 | Dell Inspiron 530 Desktop Computer
Sleep/hibernate mode
Hi, If the computer seem to wake from sleep mode for no reason? Some device settings can cause the computer to return from a power savings state when not expected. If the computer is using an optical mouse, changes in light can cause the computer to wake. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections). High Definition Audio audio may also cause the computer to wake from sleep mode. Use the following steps to prevent the these hardware devices from waking the computer:
  1. Click Start c00847244.gif , and then right-click Computer .
  2. Select Properties , and then click Device Manager in the left panel of the window.
  3. Click the plus sign ( + ) next to the device that needs to be adjusted. If you are using an optical mouse, select Mice and other pointing devices . If the computer is using an "always-on" connection, click Network Adapters . To check the high definition audio, click Sound, video, and game controllers .
  4. Double-click the name of the device to open a Properties window.
  5. Click the Power Management tab, and remove the selection from Allow this device to wake the computer . Figure 6: Power management tab for a mouse c00851648.gif NOTE: If you prevent the mouse from being able to wake the comuter, wake the computer using the Sleep button on the keyboard or from the power button on the front of the computer.
  6. Click OK , close the windows that are open, and then restart the computer.
  7. Click Start c00847244.gif , and select the Sleep/Standby button to see the problem still exists: If the problem still exists, go to the next Step.
  8. Disconnect all non-essential connected devices (printers, scanners, USB drives).
  9. Restart the computer with only the original mouse, monitor, and keyboard connected. If this resolves the sleep/standby problem, one of the connected devices was causing the problem. Replace one device and test to see if the problem occurs again. Continue adding devices and testing until the you find the device that is causing the problem.
If you have already tried all the above steps, you can try the steps below: Many software components start up automatically and run without being seen. Most of these programs are not necessary to the work performed on a computer, but can interfere with sleep/standby mode. For troubleshooting purposes use the following steps to prevent programs from starting when Windows is first opened.
  1. Click Start c00847244.gif , and then type msconfig into the Search field and then press the Enter key.
  2. The System Configuration Utility appears. Click the General tab, select Selective startup , and then and remove the check from Load startup items . c00847247.png
  3. Click OK to accept the changes and restart the computer.
  4. After completing these steps, Windows opens using Selective Startup. A small reminder may appear when Windows restarts. Select Don't show this dialog again and click OK to prevent the reminder from re-appearing every time the computer is restarted.
NOTE: To undo the changes made in this process repeat the steps above and replace the checkmark next to Load startup items .
  • If disabling Load startup items did not resolve the suspend problem, go to the next step.
  • If disabling Load startup items resolved the suspend problem, enable one startup item and test to see if the problem occurs again. Continue enabling startup items, until you find the software task that is causing the problem. Remove or update problem software.
If the problem still exists, go to the next Step. Upgrading the BIOS and keyboard software If the sleep button on the keyboard still does not work, go to the HP Software and Driver Download page , enter your computer model number into the field provided, and install any keyboard and BIOS updates for Windows Vista. Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
Feb 01, 2008 | Microsoft Windows Vista Ultimate Edition
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
How can I enable hibernation on my HP Mini 5101?
Welcome to FixYa, the world's largest product support community.
Generally all Windows OS has an option for sleep & hibernate.
Windows XP Users
  • Sleep Mode
By letting your computer idle for a period of time, i.e. not moving the mouse/touchpad, or not pressing any keys except when playing a video, the screen or desktop monitor will go dark. You can resume the computer by moving the mouse/touchpad or by pressing any key on the keyboard.
  • Hibernation or Standby mode
Click Start, click on Turn Off Computer, then click Stand By.
Windows VISTA/Windows 7 Users
To put Windows VISTA & Windows 7 in Sleep or in Hibernation, the steps basically the same. First click Start, then click the small arrow head located to the right of the Start Menu, then you click Sleep or Hibernate.
Fig. 1. Windows VISTA Start Menu. To put Windows VISTA to Sleep or Hibernate, click the small arrow head right next the Lock icon then click Sleep or Hibernate.
Fig. 2. Windows 7 Start Menu.
To put Windows 7 to Sleep or Hibernate, click the small arrow head right next the word Shut Down then click Sleep or Hibernate.
Jun 09, 2011 | HEWLETT-PACKARD HP Mini 5101 Netbook
Vista computer HP in sleep mode. How to get it
Typically you can just press the power button once, and the computer should come out of sleep mode.
Be sure to power off your comptuer regularly to reduce risk of freezing when computer enters sleep mode
To chance Sleep Mode Settings follow instructions below:
First click on the start icon at the bottom left hand corner of your screen and type into the start search box :power options , now click on "power options" it will be at the top under programs, next, under perfered plans section you need to click on " change plan settings" that is under the plan that has already been selected, this plan has a blue dot on it , come down to and click on " change advanced power settings" , now you need to scroll down to "multimedia settings " in the window that has just been displayed, click on it's box to open it up , then do the same to " when sharing media "' now click on the text to the right of "setting" it is light blue ,this will high light it and you now click on the little arrow . select " allow the computer to sleep ", lastly click on ok!
Jan 06, 2010 | HP Pavilion dv9000z Notebook
My computer does not go to sleep mode
Start > Put computer to sleep
This should work.
Aug 09, 2009 | IBM ThinkPad A21m 2628 Notebook
What is 1/4 moon symbol on top left of my compaq keyboard ? when i press it seems to put my computer into sleep mode . how do I get my computer started again ?
You are correct. The moon is sleep mode. Closing and opening the lid will often take it out of sleep mode. You might have to "unlock" the keyboard as well by entering a password (just hit return if you haven't entered a password.)
Under power options, you can select what the computer does in sleep mode.
Jun 20, 2009 | Compaq Keyboard
Xps shut down
Follow This!!!
>Start Menu
>control panel
>power options
>Change plan settings (currently selected Plan)
>Change advanced power settings
NOW, Scroll Through this LONG list of options until you see "Sleep" .
Select/Expand The Sleep item.
Expand "Allow hybrid sleep".
Set Both "On battery" and "Plugged in" to "Off".
Now Your computer will sleep as normal...
See this link to clarify if my walkthrough doesn't wor for you:
http://www.howtogeek.com/howto/windows-vista/disable-hybrid-sleep-mode/
Mar 22, 2009 | Dell XPS M1530 Notebook
Monitor going to sleep at startup
try changing the video card of your computer..
Aug 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
