Question about Miele Novotronic Premier 500 Front Load Washer
Miele novotronic w/m fault light flashing
My washing machine Check inlet and Check drain lights are flashing together. The posible cause is that the "water protection system" has reacted but I dont know what that means!It tells me to contact the service dept. they told me to check both inlet and draining filters but they seem ok. The maching also drains ok. Switching the maching on it fills ok and as soon as it goes to agitate the maching stops and the fault lights come on. Any ideas?
  • Anonymous Dec 08, 2007
    Whenever I closed the machine door some clothes prevented it from closing properly. The machine started as per usual. Then it leaked due to the clothes that prevented the door from closing properly.The fault lights were flashing. I removed the clothes from the machine and drained the water from the bottom drain. I also checked the hoses. Despite all of this the lights continue to flash. How do I stop the flashing lights to get the machine going again?
  • Anonymous Dec 18, 2007
    Not exactly the same model but the same fault. Cleaned all filters but still stops at spin cycle with flashing lights on drain fault and inlet fault.
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
I concur, our Miele Premier 300 had both Check inlet and Check drain lights flashing together after my wife had cleaned the filter. She had let some water get underthe washer into the sump. Tipping it forward to let the water run out got rid of the warning!
Posted on Dec 01, 2008
  • Greg Greenhalgh Sep 06, 2017
    Thank you 42 redcat and Fixya. Yes, it works! After checking both inlet and draining filters, if the red fault lights still illuminate and flash, simply tip the washing machine forward to drain out the remaining water from the sump. This presumably deactivated the sensors and the lights went out! Very happy!
  • 513 Answers
The following qoute is from a manual to another miele washer. basically, the water protection system is designed to trigger the safety valves when the machine is leaking(triggered by a float in the sump), to prevent water damage. On your machine I would guess that either the sensors go wacky when rattling in the agitate process, or the system is actually working and you have a leakage. Play the numbers, either you replace the parts that are likely to be leaking hoping it will do the job, or call for service, which will help you solve also an electronic fault. "The Miele water protection system The Miele Waterproof system protects all parts of the washing machine from water damage. The system consists of three main components: 1) the inlet hoses 2) the electronic unit and the washing machine housing 3) the drain hose 1) Inlet hoses ? The inlet hoses can withstand pressure of more than 7000 kPa. 2) Electronic unit and washing machine housing ? Sump Any leaking water is collected in a sump in the base of the machine. A float switches off the safety valves, preventing any more water flowing into the machine and water in the suds container is pumped away. ? Overflow protection This prevents the washing machine taking in too much water. If the water level exceeds a certain level, the drain pump switches in and pumps the excess water away. 3) Drain hose The drain hose is protected by a ventilation system which prevents the washing machine from being emptied completely."
Posted on May 08, 2006
  • 1 more comment
  • frodekri2 Apr 22, 2011
    Test
  • frodekri2 Apr 23, 2011
    Sorry. Test for water leak by tilting machine farward
    If water comes out There is most likely a leak in rubber hose from thub to pumphouse. Dismantle front of machine by unsrewing two torx screws behind bottom cover, two screws holding door lock and one 6mm screw uncerneath door gasket. Take off the steel wire holding the front gasket on place, loosen the gasket and flip the frontcover off by lifting it out in the bottom. You can now see the black rubber hose going from thub to pump hose. Check for any foreign objects penetrating the rubber hose.
Agree, having thought we has a expense ahead, simply tipping the machine forward and letting the water flow out solved the problem. This occured after the filter had been cleaned. Probably the filter had not been screwed in tight enough.
Posted on Feb 09, 2010
Have just experienced similar issue on Miele W560 with both drain and inlet lights flashing. Removing the excess water from the sump by tipping the machine forward cured the issue. Great. Thanks!!
Posted on Jul 28, 2010
    Problem Solver:
Miele w980 door wont open water in the sump and warning lights on check inlets.please can you tell were to look for the leaks as i am continuosly tipping machine forward and empyting the sump is it the hose from the soap draw to the drum assembly. thanks
Posted on Jul 12, 2010
    New Friend:
My old but happy Miele W360:
I thought I had an expense ahead!! After cleaning the filter a few times and watching the two warning lights still flash, decided to Google problem.
Read comments below and by simply tipping the machine forward and not expecting to see water flow out the front did solve the problem. Being female, I tighten but never overtighten fittings (just in case I have to return to the problem) I may not have screwed the filter on tight enough. Have now tightened again and working tickety boo now!
Posted on Mar 16, 2013
  • Andi Mar 16, 2013
    New Friend:
    Problem Solver:
  • 5 Answers
I have a Miele W520.
Both lights flashing usually is caused by a water leak into the case of the machine which trips the float switch in the base. You can reset this by tipping the machine forwards at 45 degrees and allowing the water to drain out on to the floor. It will reset everything but if you still have a leak it will trip ou again due to the float switch.
I had the same problem with the 2 red lights flashing, which was fixed by emptying the float tray as above.
On further investigation I found that the door seal had rubbed on itself at the 6 o'clock position and had worn a small hole which was causing the water leak.
To replace or repair the Door Seal you will need to remove the front panel.
1. Turn power off and unplug machine after opening door.
2. Remove the front panel lower kick plate by inserting a thin ruler between the kick plate and front panel about 4 inches from each end and lever down until it releases.
3. Remove the 2 screws at the door lock switch on the front panel.
4. With the kick plate removed you will see 2 screws at each lower edge of the front panel, remove these 4 screws.
5. Remove the spring loaded band from around the edge of the door seal facing you and after that release the seal from the front panel and push in.
6. Remove the hex bolt from the 6 o'clock position just below the door seal on the front panel.
7. You should now be able to lower the front panel out of the locating pins and remove it.
8. With front panel removed you will be able to remove the tensioning band which holds the door seal in place around the drum by undoing the screw at the right hand side of the band at the 3 o'clock position. It is accessible from above with a long bladed screwdriver. Take note of how far it is tensioned on the thread of the screw and try not to undo it all the way or you may lose the nut on the band.
9. Once you have removed the band, slip the seal off the drum and slide the water outlet to the seal from the dispenser.
10. When you replace the seal do not do the tensioning band up too tightly or you will hear it squeak when you spin the drum in either direction.
11.Reassembly is the reverse of removal, taking care to put the door manual release strap through the inner slot in the front panel.
I repaired my door seal with Silicone Sealant and loose weave fabric tape after rubbing it clean with alcohol as i didn't want to pay $100 for a new seal from Miele.
miele novotronic w/m fault light flashing - 3_13_2013_1_40_54_am.jpg
Posted on Mar 13, 2013
  • Ellen
    Ellen Apr 27, 2016
    Thank you, this also solved my problem too. Seems like this is a common problem with Miele?
Rinse indicator lights flashes - - -
Posted on Jan 01, 2011
I have a Miele Novotronic W 828 the check inlet red light is flashing - what do I do?
Hi dear. Seems to me your machine needs new inlet valve replacement.Due to it's age, it's quite normal. Thanks.
Jan 26, 2016 | Miele Washing Machines
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
What do you do if the Miele washing machine's check drain and inlet light is on?
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Feb 15, 2010 | Miele Novotronic Premier 500 Front Load...
Both red lights flashing for check inlet and drain.I have checked both and they are O.K.I have also checked filter.
Feb 09, 2010 | Miele Novotronic Premier 500 Front Load...
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Meile W 844 Drum not turning
Its probably the motor brushes you need to replace them
May 10, 2009 | Miele Novotronic W1918A Front Load Washer
Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
10,486 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
