Question about Frigidaire GLTF2940ES Front Load Washer
Error message washer get a error messege when turned on ,reset and it works model# GLTF2940ES
  • Anonymous Dec 31, 2008
    When push star error
  • stpattyday Jan 03, 2009
    My daughter has the same problem, I moved the washer from Arizona to Michigan and she is now trying to use it. She ran 1 cycle empty, then when she put clothes in it and ran it... it won't spin out and E20 came up.
    Now, how does she reset it?? You say reset it after she checks to make sure the drain is clear. How do you reset it?
    Sergeant:
  • 276 Answers
Check out the drainage area of the machine is it cleaned or dirty.if dirty or any thing got stuck there just clean it to avoid the error again.
Posted on Nov 18, 2008
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
What does error code 18h mean
Hey friend, thank you for the post!
I see you are getting an 18h code on your front load washer. Normally any error code would have the letter E or F in it. I would suggest that stands for 18 hour delay start cycle, you could do a reset on your washer by disconnecting power to it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this information is helpful. -Matt
Jul 21, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do i reset/delete all the data codes for a frigidaire galley model GLTF2940s53
Disconnect power to reset the control to return washer to normal
operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
• Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation
Jul 17, 2014 | Frigidaire GLTF2940ES Front Load Washer
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do you take the rubber seal off my frigidaire washer
Good Morning Laura, thank you for your post!
I understand your Frigidaire washer GLTF2940ES will not complete a cycle. Let's try resetting your washer. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your appliance on.
If resetting the power does not correct the issue, then you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Best regards!
Jan 29, 2014 | Frigidaire GLTF2940ES Front Load Washer
Error codes, we've cleaned out the filter. Do we need to reset the Washer code? and how do we do that? Frigidaire GLTF2940ES
Good Morning Kat, thank you for your question!
First, what error code does your washer displayed? Meanwhile, one of the best ways to determine if your appliance has a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker. It is important to wait roughly ten minutes and then turn on the unit. I ask that you please follow up with a comment on the post, at your convenience, to inform me if the error code does not clear so I may advise you the meaning of the error code and/or possibilities of the issue the unit could be experiencing. Thank you and best of luck!
Sep 22, 2013 | Frigidaire GLTF2940ES Front Load Washer
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire gallaxy front load washer
Have you tried a simple reset? turning it off, unplugging it for a few minutes and plugging it back in?
Aug 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
