Panasonic PT-52LCX66 When I go to turn my TV on it starts up like normal but then after like 30 seconds shuts back down and the lamp indicator blinks red one time and I've got a new bulb in June of 2010 and I have reset the lamp timer. My feeling is it is the lamp which would really annoy me because my last one lasted like 4 years and now this one about a year. Any help out there? I don't want to have to replace the bulb every year at that rate I might as well just get a new TV...Any Ideas?
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Panasonic Projection TV Lamp Timer Resetr
Three orange power blinks indicates a 'Malfunction 5', and that your unit requires servicing. You can try pressing POWER on the unit for over 7 seconds, and then turning the set back on after 5 more seconds. If this doesn't help the set needs servicing.
If you didn't reset the lamp timer after replacing it, you might try that by following these steps.
If you think browsing the troubleshooting section of your operating manual may help, you can access it here.
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know. If you need further assistance or if this did not help you please comment to this post and I will try to help you further. Thanks for using FixYa asnowman
To reset lamp timer in Panasonic PT-52LCX66.. Press and hold Volume Down button on TV front and press and hold 0 (zero) button on TV remote at same time for 6 seconds, a lamp reset message will appear on TV screen. Thanks.
