Question about HP Compaq Presario v3000z Notebook
Control panel i got my new laptop but in control panel don't have "printer and fax" icon like the others laptop. i want to install by using compaq installer cd but i also don't have that cd. so,what should i do?? if that icon not existed, i can't to install any printer. my laptop's brand is HP compaq and i'm using windows vista ultimate..please guys help me!
  • shahida
    shahida Sep 12, 2008
    i did my installation through canon site because my printer driver is canon pixma ip1880..but it failed and shows "processing cannot be continued because the Print Spooler service has been stopped. Restart the computer to start the Print Spooler service and then try again." i can't restart and when i find out the print spooler like this way:
    click Start > run
    type services.msc
    find Print spooler
    double click Print spooler
    make sure "startup type" in Automatic
    if ‘Service status’ is ‘Stopped’, click ‘start’ to start the services
    but i stuck while i find "print spooler" because it is not exist
    then,what should i do??
    President:
  • 2,961 Answers
You haven't posted your printer details, so go to the printer manufacturer site yourself and select your model and then Vista, then the driver will be available for download
Posted on Sep 12, 2008
  • andrew pester
    andrew pester Sep 12, 2008
    Remove the printer, uninstal the driver from add/remove programmes and start again, as this can happen sometimes, and also try to use a different usb port than last time to stop a repeat spooler problem.
    Problem Solver:
  • 6 Answers
Go to the manufacturer of your printer and download the drivers for it then run the download and follow the directions on the installer do not plug your printer into your computer until it asks you too once the installer is finished you will have the printer icon
The printer is displaying error: B0605 on the screen
HI............
Issue Description: Print cannot boot up into ready state with an error message shown on printer control panel. The error messages include ERROR: B0601/ B0602/ B0603/ B0604/ B0605. Root Cause: Firmware crashes. Note: Inappropriate behavior may cause firmware crash. For example, a printer is turned off when critical firmware update is undergoing. Solution: Firmware Update Utility.
There are two use cases when encountering the issue: Instructions for Use case 1: driver is previously installed on PC
  1. Place printer in bootcode mode.
    1. Hold down the Cancel and OK buttons.
    2. Power on printer.
    3. Continue to hold down buttons until control panel dislpays Hewlett- Packard on the first line and Bootcode on the second line.
  2. c01688132.jpg Please observe the printer control panel and verify Downloading Update Data is displayed on control panel followed by Programming App Flash; please wait for upgrade utility to finish. Printer would be restarted automatically and the control panel display would show Ready .
Then the firmware is now successfully recovered. Instructions for use case 2: driver is NOT previously installed
    1. Insert printer installation CD.
    2. In Windows OS, please go to Start , Settings , Printers and Faxes .
    3. Click Add a printer to start Add Printer Wizard as shown blow and click on Next button. c01688133.jpg
    4. Check Local printer attached to this computer box; uncheck Automatically detect and Install my Plug and Play printer box and click on Next button. c01688134.jpg
    5. Select FILE:(Print to File) in the Use the following port: dropdown list and click on Next button. c01688135.jpg
    7. Browse to the CD drive in which the printer installation CD is inserted previously and click OK button. c01688137.jpg c01688138.jpg
    8. Highlight the HP LaserJet P2050 Series PCL 6 found in the printer installation CD and click on Next button. c01688138.jpg
    9. Specify the Printer name and click on Next button.
    10. Select No for Do you want to print a test page? and click on Next . c01688139.jpg
    11. Click the Finish button and allow driver to install as shown below. c01688140.jpg
    12. Verify printer is listed in Printer and Faxes window as shown below: c01688141.jpg
  1. Place P2055 in boot code mode:
    3. Continue to hold down buttons until control panel dislpays Hewlett-Packard on the first line and Bootcode on the second line Printer is now in bootcode mode.
  2. In the Printer and Faxes window, right click on the HP LaserJet P2050 Series PCL6 icon and select Properties .
  3. Click the Ports tab and view the USB ports as shown below.
    NOTE: If more than one (USB001) please take note of all listed ports, as other installed printers may have USB ports (USB002, USB003, etc). c01688142.jpg
  4. Close Properties window.
  5. Plug in USB cable from to PC
  6. The Found New Hardware Wizard will pop up, and tje printer USB enumeration will happen.
  7. Open printer properties and select Ports tab again.
  8. In ports tab, tick the correct port that the HP LaserJet P2050 series printer is enumerated on and click OK . c01688143.jpg
  9. Click Cancel on Found New Hardware wizard window.
    NOTE: Not the driver is installed and it is pointed to correct USB port.
  10. Run HP LJ P2055 Firmware Update Utility.
Sep 21, 2011 | Computers & Internet
LOST INSTRUCT MANUAL. HOW DO I INSTALL NEW INK EPSON SX425W?
Do the below steps.
First of all you have to prepare your printer drivers. This must be CD or DVD disc which you already have from printer manufacturer or supplier. If don"t you can check for the latest drivers on manufacturer website.
Now let"s start. Click on Start button, next Control Panel and the window shown below will appear at the screen. Please note the window below is in new Windows XP style. If you like old classic style of Control panel click on top left in task pane. Next click on Printers and Other Hardware Icon or Printer and Faxes in classic view.
1268_control_panel.jpg Now you can select Add printer... from Pick a task section or Printer and Faxes icon to continue with printer installation If you select Printer and Faxes icon next click on top left in Printer Tasks and on Add Printer task.
1269_control_panel_printer.jpg When to screen appear Welcome to the Add Pinter Wizard. Please read the note and skip the wizard if your printer is connected to USB or any other Plug & Play port. If not click on Next.
1270_control_panel_add_printer_wizard.jpg Now select Local printer attached to this computer for printer connected directly to your PC or select A network printer, or a printer attached to another computer for printer connected to your office or home network. Automatically detect and install my Plug and Play printer option needs to be selected when you don"t have any information about your printer model and drivers. Click on Next.
1271_control_panel_add_printer_wizard1.jpg Next select Printer Port from drop-down menu where the printer is connected or Create a new port. Click Next.
1272_control_panel_add_printer_wizard2.jpg Now from the left list select manufacturer of your printer, and next click in right list on Printer model which you want to install. Best result you can get if you have correct and updated Printer drivers on CD or DVD disc and click on Have Disc button to select this drivers. When correct drivers are selected Windows will install the files and you will get new icon in Printer and Faxes section in Control Panel.
1273_control_panel_add_printer_wizard3.jpg When installation of drivers complete you can right click on Printer icon and select Properties from menu to setup the features and settings of your printer
Now you can give print.Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 22, 2011 | Office Equipment & Supplies
I have a mini laptop but i couldnt print all my reports because i dont know how to install our hp photosmart printer c4480......i ask for your assistance............thank you very much
There are 2 ways of solving your problem.
1 If your mini laptop has a CD player, then load the CD which came with the printer on your laptop. Then click on the printer& faxes in the start menu. On the page displayed check for icon of your printer. Click on the icon and make it your default printer. Now you can start printing the documents.
2 You can go to web site of HP. Click on support. Go to drivers. From the list check the driver for your model and down load it. Once download is complete install it. Check for the icon in the printers & faxes page in the control panel. Make it your default printer. You can now print the documents.
Feb 14, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Unable to install HP640C Printer driver
Delete it from the Add Printer Wizard
  1. Click Start .
  2. Click Control Panel .
  3. Click Printers and Other Hardware .
  4. Click Printers and Faxes .
  5. Under Pick a task heading, click View installed printers or fax printers or under the heading or pick a control panel icon , click Printers and Faxes .
  6. Right-click the printer icon.
  7. Click Delete from the drop down menu.
Windows XP
  1. Click Start , Control Panel .
  2. Double-click Add or Remove Programs .
  3. Highlight the printer to be removed and click Change /Remove .
If the driver comes with an uninstall feature, follow the steps below:
  1. Click Start and Programs .
  2. In the Programs list, highlight the name of the printer to uninstall.
  3. Click Uninstall .
  4. Click Next .
  5. Click Uninstall .
  6. Click Restart .
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Dec 30, 2010 | HP DeskJet 640c InkJet Printer
When i connect the usb cable to my laptop,y it cant print anything???please help..is it need some installation cd or some software coz this printer belongs to my friend....
Hello!
Once you connected the printer to your laptop see if it was able to detect the printer,
- go to Control Panel
- look for Printers and Faxes and open it
  • And if you are able to find an icon with the brand of your printer, so it was able to detect your printer and you don't need any cd or drivers for it.
to be be able to print on your printer, right click (still on Printer and Faxes) then select Properties. On the printers menu click PORTS tab then at the bottom find or select USB port, then click OK, after the configuration you can now print.
  • And if you do not find any printers on Printers and Faxes folder, meaning you need the installation cd or software driver for your printer.
to install the driver,
- connect printer to your laptop, then insert cd and follow the instructions---its just a simple and easy for you to follow.
Hope I was able to help.
Sep 13, 2010 | Brother HL-5240 Laser Printer
I disconnected the printer from the tower for computer service with a local vendor(blue screen). Repair completed. When I reconnected the printer, I discovered that I was unable to print documents from the...
Open Control Panel, Printers and faxes. Check if there is icon for your printer. If not, you have to install the driver using CD that comes with the printer.
Blue screen often means very badly broken windows installation and your vendor probably reinstalled it as new installation. Therefore your printer may not be installed.
Jun 15, 2010 | Dell 924 All-in-One InkJet Printer
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
Can no longer fax or scan
got to control panel and uninstall all the applications and drivers related to your printer in the machine running vista. Then place the printer installation CD came with your printer in the CD drive. Now just connect your printer to machine and switch it on. Vista should display new Hardware connected or any other sound alert acknowledging that printer is connected to your machine. If it prompts for driver installation, select it to search for drivers automatically. Before that make sure that your printer installation cd is in drive. Vista will automatically search for the drivers and installs it. If it's not, then the cd came with your printer may not have drivers for vista. go to HP website and download driver for vista and install it.
Jul 28, 2009 | HP Officejet 6310 All-In-One InkJet...
I AM ON THE WINDOWS XP AFTER INSTALLING THE DRIVER THE TEST PAGE IS PRINTED BY THE PRINTER BUT ON GIVING COMMAND FOR OTHER PRINTING THE PRINTER DOES NOT PRINT
Got to: start>settings(classic view)>control panel>printers and faxes.
An icon for your printer should be there. Right click the printer icon and select "use as default". While in control panel, you can run the troubleshooter. Sometimes it works. Sometimes the software doesn't install correctly. Uninstall the software from the add/remove software in control panel, then re-install the printer software.
Feb 03, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Printer
Go to Control Panel look and see what printer or printers are connected to your PC.
Then I would try to reinstall my new printer.
May 17, 2017 | Compaq Office Equipment & Supplies
HP Compaq Presario v3000z Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
