Question about Philips Televison & Video
Hi, I have a PHILIPS DVDR5520H/05 HDD & DVD player/Recorder. When i plug it in the light on the OK button comes on and the display reads STARTING and a symbol below 0(((. Then the symbol disappears and the STARTING display just stays on. None of the buttons on the front of the device appear to work and on the screen the Philips logo appears then disappears. Any thoughts welcome.
5 Suggested Answers
  • 396 Answers
SOURCE: Philips HDRW720 won't turn on
I think Philips must have a timer on this unit to fail, I am also having the same problem and I think the hard drive failed. I currently have installed a new drive and held the play and open close buttons down when the power comes up. It will ask for a cd to be installed when initializing the drive. I am currently searching for that cd and will let you know if any luck with the install.
Posted on Jan 01, 2008
SOURCE: Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Posted on Apr 16, 2008
SOURCE: DVD player will not read any disc
SAME PROBLEM EXACTLY
Posted on Aug 04, 2008
SOURCE: I have a Philips dvdr5520h/05
try all the above but wheh u tpye in the 159 121212 005 255 then tpye the 2960 on to it then press the play button then press home to exit
Posted on Nov 06, 2008
  • 4 Answers
SOURCE: Philips DVDR3570H/05 constantly looping on startup
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Posted on Dec 06, 2009
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
I have a Philips flat screen TV, Model 50PF9630A/37 i replaced some blown cap on the power supply board now the red light flashes in a sequence of 7 flashes, any assistance would be appreciated.Guy
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
Jan 10, 2017 | Philips Televison & Video
What is the code for philips dvd player DVP3570?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Jan 08, 2017 | RCA Televison & Video
Hi Bush tv is flashing but not turning on at all. What can i do?
Hi press & hold on-off button while holding unplug power plug from the wall continue holding for 30 seconds.,.Plug in the POWER plug while holding on/off button hold for another 30 seconds ......,.Good luck.,
Jan 08, 2017 | Televison & Video
How to eject a DVD disc stock inside of Samsung blue ray DVD player does not have DVD tray
There are many reasons for this fault. Visit the site linked below for more information. Type in the brand name of the device in the search box at the top of the display window to get gathered all the related posts. http://electronicshelponline.blogspot.com/
Jan 08, 2017 | Samsung Televison & Video
My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Jan 07, 2017 | Toshiba Televison & Video
My govideo recorder model R6530 no disk appears when i put a DVD+R what am i doing wrong
The inability to read DVD+R disks probably is the reason the recorder was offered for sale on eBay.
Jan 07, 2017 | GoVideo Televison & Video
The DVD player on my Bush 32inch television takes in DVD's but just displays 'No Disc' the model number is DLED32165HDDVD Is it something I can fix?
The player has failed, these types of devices are not fixed as the cost to repair is in some cases more than a new one. More than likely you could not get parts for it even if you knew the cause, which is most likely a failed laser light
Jan 06, 2017 | Bush Televison & Video
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
Blu Ray - DVD player does not respond to remote
Did you check to see if remote pickup on player is cleal and not being blocked?
Dec 15, 2013 | Televison & Video
Televison & Video Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
