Question about Creative Labs SBS 330 Computer Speakers
Creative speakers 2.1 Deteriorated sound quality
I have purchased Creative 2.1 a few years back. I am finding that the sound quality has deteriorated recently. A lot of dust seems to have settled on the speakers. Could this be a reasonfor bad sound quality? Frankly I haven't done much maintenance myself. I will be happy to get some tips on how to clean the dust and keep it from getting inside.
    President:
  • 373 Answers
Yes.speakers like all the other computers parts need to be maintained very well.dust can deteriorate the sound quality.Regular servicing might help out to get the original quality.Else you can do it on your own by cleaning with a normal hand brush.Hope this helps you out.Please do rate If this could solve your problem.
Posted on Dec 05, 2008
Need replacement speaker for clarion psw160
I had the same issue. The edge of the speaker deteriorated. I sent the speaker to Orange County Speaker in Garden Grove, Ca. They will repair/re-test/and certify the speaker for $45.00. There is no direct replacement due to the bolt pattern and screw hole in the magnet.
May 11, 2013 | Clarion PSW160 Car Speaker
T135D-S1234 HAS BURNED TWO HARD DRIVES
Unfortunately the quality of new Non-SSD Hard Drives has drastically deteriorated over the last few years. Western Digital makes the best Non-SSD drives but even they have become to careless on their quality control testing. I would recommend getting a SSD hard drive. They produce less heat and are much faster. Also get a can of compressed air and clean out your laptop's vents and fans.
May 13, 2012 | Computers & Internet
My toshiba l505d-gs6000 laptop has poor sound. What can i do?
The best thing you can do that will save a lot of time and energy is to just hook it up to another speaker set. That way you get surround sound. Otherwise, assuming that the speakers were once good and has deteriorated, then you'd need to purchase new speakers.
Oct 22, 2010 | Toshiba Satellite L505DGS6000 Notebook
Recently, I purchased a used set of Bose 901 VI speakers. They are crackling when base sounds play. What is the problem? Was I duped? Is it the speakers or the amp or the volume. Can I repair?
It is likely that the speakers were damaged by someone playing the system at way too high a level.
If the noise sounds like a scraping, then it is the speakers themselves.
If the noise sounds like a breaking sound then it is likely the amplifier.
Another possibility is that if you are not useing a Bose amplifier, then your amp may not be capable of properly powering the speakers.
Jan 18, 2010 | Bose 901 VI Main / Stereo Speaker
CLARION MARINE SPEAKERS CONE DETERIORATED
of course, the only problem is finding someone to do it, and is the speaker really that nice and worth the money
Mar 21, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Optical port doors on my av reciever ( sony ) broke off and now the optical cable does not have a tight fit
Hi vbuell!
On most AV equipment, the door on the optical port is there more to keep dust and debris out of the port than anything else. I suppose it could put a small amount of pressure on the cable end as well, but I don't think it should be significant.
If your sound quality has not deteriorated, then the optical cable is still working OK and I wouldn't worry about the situation too much. There are many ways that you could tighten up the fit, but most risk getting debris into the fitting, which is obviously not a good thing.
If your sound quality has deteriorated, I would first get a can of compressed air (you can get one at any store that sells computer parts for a few dollars) and blow out the "hole" where the optical cable plugs in. Plug in the cable again and see if your sound quality has returned. If so, you are good to go. If not, I'd make sure that your cable is working (if it's plugged it at the other end, the end that goes into the receiver should be lit up). If still no sound, you may need to take the unit to an authorized Sony repair facility, which you can find at www.sony.com.
Good luck, and I hope your problem is resolved. If you feel it is appropriate, I would appreciate a rating on my advice that I've given.
Bob
Oct 16, 2008 | Audio Players & Recorders
Need a new surround for '96 JL AUDIO W6 12"
Call Jeff at California Sound in Wichita, KS 316-686-2254. He is a JL expert!
Jul 20, 2008 | Jl Audio 12W3 Car Subwoofer
Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Jan 21, 2008 | Audio Players & Recorders
POOR SOUND QUALITY
get some woofers and amplifiers attached to it.they wont cost u much and u will then have an excellent sound.....
Dec 01, 2007 | Audio Players & Recorders
Creative Labs SBS 330 Computer Speakers Logo
482 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
