Question about Pioneer GM-X324 Car Audio Amplifier
Amp cuts off
I recently changed my rca cables. im now using lighnint audio lbx3.they work fine except now that the bass cuts off.i switched around the cable and it only seems that it that the rca that goes from my pionner amp to the eq may be the problem.b4 i used stinger cable for the pioneer and it worked fine.could the lightning audio cable be the problem or is my amp fried?
  • steve petridis May 09, 2006
    i checked the ground and everything seems to be fine fine
  • steve petridis May 10, 2006
    not only the ground isnt the problem,i hear the bass almsot never.maybe my amp is finished
    Scholar:
  • 148 Answers
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
Posted on May 07, 2006
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
Jan 04, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Noise in my car amp.
sounds like you have a bad ground going to your rca's. try running a wire from ground to the shield of your rcas and see if the noise goes away.
Apr 19, 2009 | Rockford Fosgate Power 1050S Car Audio...
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-X324 Car Audio Amplifier Logo
101 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
