Thomson 28WF45EG keeps switching itself off after 10 minutes then takes many attempts to switch back on again
SOURCE: TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Posted on Apr 22, 2008
  • 2920 Answers
SOURCE: thomson hd44lpw62 rear projection tv
you have a weak power supply
Posted on Aug 26, 2008
  • 2920 Answers
SOURCE: Philips 26PF4310 Keeps switching off when I power it up
it sounds as though your power supply went out
Posted on Oct 29, 2008
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
I had the same issue but instead of shorting out the sensor, I removed the bulb assembly, cleaned the interior of the assembly and TV the best that I could with a vaccum and small paint brush. Once cleaned, I reinstalled the bulb assembly and the TV has worked for the last eight months with no problem.
Posted on Jun 27, 2009
My Thomson TV 28WF401G is about 7 years old and has now started to automatically switch itself off after only a few minutes of being on. The red 'off' LED flashes several times, stops, flashes...
U have tools like a soldering Iron and roll of solders?Can u also do basic soldering works?Yes take the tv aparts and resolders the FBT-(flyback transformer) that the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).Also the tv video board that the board that hook up to the tv CRT-(tv tube) tube neck hook on to this video board.Resolders that board too.70-80% will get the tv working again.
Aug 19, 2011 | Thomson 28VK25US TV
My laptop takes a number of attmpts to switch on!!
Sounds like it may either be your motherboard or your RAM. I would suggest reinstalling the OS or resetting the machine back to the factory state. If it does not solve your problem then you have to consider the possibility that it is the hardware which is having issues. You may have to send it in to Packard if reinstalling the OS does not work.
May 21, 2010 | Computers & Internet
Well i put a new starter on the car the the theft light stays on will it fix the problem if i take it to the dearler to put an ingition lock cyclinder in it because my car want start.
Your Passlock may need to relearn the ignition keys, if the ignition lock has gone bad like my in-laws Grand Am Gt, here is what i did so they will not get stranded any more. Buy a Passlock by pass module for around $70.00. You can order one from GMPASSLOCK.COM in the mean time try resetting the Passlock. Good luck
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure
1.) Turn ON the ignition, with the engine OFF.
2.) Attempt to start the engine, then release the key to ON; the vehicle will not start.
3.) Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF.
4.) Turn OFF the ignition switch, and wait 5 seconds.
5.) Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes.
The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6.) Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
7.) With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Without a scan tool you may have momentary starter interruptions while history clears itself. Keep me posted, be glad to know you got your car running 100% again soon.
Jan 13, 2010 | 2001 Chevrolet Malibu
Got a stuck key out of the ignition, but it activated theft deterrent system, unhooked the battery cables for a while and rehooked back up. system did not reset. is there a way to reset it without taking...
If the ignition lock has not been damaged, ( that's where the GM Passlock system reads the ignition key) here is how you reset the Passlock to youe keys.
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Good luck and keep me posted, be glad to know you got your car running again.
Nov 16, 2009 | 2005 Pontiac Grand Prix
Thompson 52jw643 is stuck in standby, when switch on red led appears, changes to yellow for approx 1-2 sec, sounds like trying to start and reverts to red. sometimes flashes red once. any help greatfully...
I have a similar problem with Thomson 52JW643 S in that it takes at least 12 to 16 attempts before it eventually turns on very very annoying !!!!!!! turns from red to yellow to green then back to red and then same again until she feels like switching on then perfect picture sound and quality ??????? can any one advise please
Jun 27, 2009 | Thomson Televison & Video
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Dec 01, 2008 | JVC AV-32D305 32" TV
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Dec 02, 2007 | Thomson LCDB 03B 27 in. Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
