Question about Xerox Office Equipment & Supplies
How to Configure Network Scanning on a Xerox Phaser 6180MFP-D We have a Xerox Phaser 6180MFP-D All-in-One printer in our small SBS2003 LAN. I was just asked to configure scanning. I'm trying to set it up to scan to a shared folder in our server that runs SBS. Both the folder and the share have rights for everybody to read/write, and I think I'm following the instructions but I keep on getting an error when trying to scan. The error says that it can't login to the computer. I tried with both administrator and DOMAIN\administrator. I'm configuring the printer with its web interface: CentreWare.
  • 2072 Answers
SOURCE: domain problem
Call 1-800-821-2797, have your serial number and ask for second level support, They will resolve this issue for you. They are extremely helpful.
Posted on Mar 14, 2008
SOURCE: trouble sharing pixma ip3000
my cd installer lost
Posted on Apr 28, 2008
  • 2072 Answers
SOURCE: Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Posted on Jan 11, 2009
  • 2072 Answers
SOURCE: recently got a second hand xerox document centre
You need a scan to PC kit that has to be added to the machine.
Posted on Mar 11, 2009
  • 78 Answers
SOURCE: I have an IR5050 copier that is scanning to
use the Remote User Interface\\computer name\file name should get to destination as long as user name and pass word are ok
Posted on Sep 12, 2009
Fax confirmation sheet on a Xerox Phaser 6180MFP
Not quite sure what you mean here, it can be switched either on or off within the internal settings. Normally the default would be off in a large office due to wasted pages, but in "print for pay" a customer has a receipt that the fax had arrived at it's destination.
Good luck.
Jun 13, 2014 | Xerox Phaser 6180N Laser Printer
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
Xerox 3635mfp: On defining network scanning one needs to define the default file repository. This causes no problem but on pressing "Apply" (Via explorer interface to IP of printer) the system...
Xerox are aware of this problem and are working on a solution. I think the workaround is using capital letters for the administrator. Xerox software support should be able to help with this.
Jan 17, 2011 | Xerox Phaser 3635MFP/X Multifunction...
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180MFP i have replaced toners
There are a couple of possibilities here.
Is the printer on a 'page pack' contract ?
Are the toners really chipped for the printer you have ?
There are 8 printers (including the multifunction variants as yours is) that take a SIMILAR cartridge.
They vary in capacity and chip. Some remanufacturers don't realise and have been sening out cartidges for these with the wrong chip fitted.
There has also been a bad batch of chips (a while ago now).
The solution is quuite simple, contact your supplier tell them what the problem is (error message etc) and they should be able to check the cartridge in their test printer (a GOOD remanufacturer will have a test printer for each of the cartridges they produce - how could they test their product otherwise !!).
Oct 09, 2009 | Xerox 6180MFP/D Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
838 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
