Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Portable dishwasher The portable dishwasher runs wells but the hose continues to come off from pressure build-up. Changed adaptor but didn't fix the problem.
  • Anonymous Mar 19, 2014
    Have a kenmore portable dishwasher that runs fine, but water continuously runs thru the bottom of the connector hose. Is this normal
    President:
  • 878 Answers
The first thing you might want to do is check the water pressure in the house. Ideal water pressure should be from 55psi to 75psi max. I have seen homes that had pressure around 125 psi which will cause pressure leaks in water heaters, softners, washer valves, r/o systems. Check to see that all, if any inlet screens are clear and free from any grit and sand. It's possible that your inlet water valve (wd10m0010) has become restricted. Other than that, the complete uncoupler hose assy. part number is wd24m0030. These parts are for the dishwasher model ending in gsc3400j00bb. They are the same for model number ending in 00ww. Good luck.
Posted on May 07, 2006
MY DISHWASHER IS NOT DRAINING AT ALL. WATER IS STANDING IN THE BOTTOM OF THE DISHWASHER
Posted on Jun 23, 2008
Danby portable Dishwasher advances from pre-rinse to dry and then beeps continuously and dry light continues to blink. Doesn't proceed, reset or stop cycle. Just continues to blink.
I actually found out (one of) the solution to this by accident. It could be the water source is not providing enough pressure
I purchased a Danby DDW1899W-1 and, using the connector screwed into my utility sink in the basement, I connected the water. When I tried to run a cycle, I had the same results (filled/emptied 4-5 times, beeped and went to dry cycle).
My alternate, long term plan was to put a Y-splitter (with shutoffs) on the hot water line for my washer, and have one hose go to the dishwasher when needed. I purchased a washer line hose from Home Depot and a 3/4" to Quick Connect fitting from Ace Hardware and then connected the dishwasher to this.
And, Voila! Problem solved!!!
To confirm this was the solution, after the first completed cycle, I connected back to the faucet and, once again had the fill/empty/beep/dry problem. Reverting to the split washer water feed, it was able to run the cycles properly (again!!!)
So you may just need a line that will supply more water pressure to the dishwasher.
Good luck and, hopefully, this solves the problem.
MP
Oct 18, 2014 | Danby Dishwashers
Kitchen faucet quick connect adaptor like portable dishwasher, read on
You can't find a portable dishwasher connector? Try an appliance parts supplier.
May 17, 2014 | Plumb Pak Faucet Adapter
My dishwasher Bosch SHEAR55UC show E24 on screen , didn't work all of process ?
Hi.
E24 is draining error:
Turn off the appliance. Check drain well and filter for blockage. Clean drain. Check drain hose at the back to make sure it is not kinked. Dry water from inside the appliance manually (with power not connected). If that does not fix the problem, then pressure switch in the drain system is usually responsible. The part to be tested are pump, pressure switch and drain lines.
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I bought a 97 gp 1200 waverunner and the first few times i took it out it ran great, i changed the spark plugs because it wasn't opening completly up at wide open throttle. I put it the water and it...
THE BEST WAY TO CLEAN OUT YOUR INGINE AND HOSES IS TO HOOK UP THE FLUSH HOSE TO THE SIDE OF THE WATERCRAFT ,,,,IF YOU DONT HAVE THE ADAPTER CONECTION HOSE YOU WILL NEED TO GET ONE ITS A VERRY IMPORTENT PART OF MANTENACE ,,,,YOU NEED TO FLUSH IT OUT EVERY TIME YOU TAKE IT OUT OF THE WATER TO KEEP ALL THE SAND FROM BUILDING UP IN YOUR COOLING SYSTEM,, AND TO GET ALL SALTWATER OUT THE SALTWATER WILL EAT AWAY THE HEAD LITTLE BY LITTLE,,PLEASE NOTE SOME MODELS HAVE A HOOKUP IN THE VERRY BACK WHERE YOU CAN HOOK A REGALAR WATER HOSE TO,,,HOPE THIS HELPS.
Jul 19, 2011 | Yamaha Alp 40 Motorcycles
Hi I have a problem with my Bosch SHU43CO6UC/22 dishwasher. using "power scrub plus" and "regular" cycles it will continue to fill and overflow the door, after the cycle has run even...
The bosch dishwashers use a fill valve that is attatched to the inlet hose. yours is stuck in the open position. this usually happens when you have hard water, as the minerals build up on the sealing surface of the water valve. there is no easy fix. the fill hose will have to be replaced. It requires removing the machine, removing the bottom pan, and changing the hose connections.
the valve uses water pressure to stay closed. if the water pressure is very low coming in, it may not be enough to close the valve. there is a filter screen between the fill hose, and where it connects to your water valve. try cleaning the filter out and see if that makes a difference. If not, you will have to get the hose changed.
Nov 19, 2010 | Dishwashers
My portable dishwasher hose that attaches to the faucet is to short for where I want my portable dishwasher to sit. I would like for it to sit in one spot. I am not allowed to alter or cut holes in the...
You should be able to find extension or replacement hoses that you can use to extend the existing hoses at a hardware store. If you need to join two hoses that have female connectors, adaptors with two male connections are available.
Nov 09, 2009 | Dishwashers
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
I have a portable ''GE quiet power'' portable dishwasher and the hose won't fit on my new faucet - is there some sort of adaptor I can buy for the sink so it will fit properly?
Yes, you need to know whether your faucet is male or female thread (threads on outside or inside) and buy an adapter that will fit into the faucet where the aerator normally sits. These are generally available in the plumbing section of your local hardware store. Make sure you know your diameters as well (O.D. stands for Outside Diameter and is usually male thread where as I.D. stands for Inside Diameter and is usually female thread)
Jul 03, 2009 | GE Dishwashers
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Need portable DW but have low hot water pressure in apartment
all dishwashers i am aware off have their own heater and are better connected to cold not hot water
Jun 26, 2008 | Dishwashers
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
465 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
