Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also very noisey , got a new pump but this wont run at all, i seem to have 240 v olts going to the pump buy nothing happening, any ideas please
  • tubby2 Sep 12, 2008
    thanks for the reply , its turned out to be the new pump i got was faulty, the shop swapped it for another and its working fine now. how unlucky is it to get a new pump thats faulty . once again thanks for the advice
  • 1,239 Answers
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
Posted on Sep 12, 2008
Operating manual for Hoover 1300 washing machine dryer (wdm 130)?
Sorry but this forum does not supply any type of manual or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 18, 2011 | Hoover Washing Machines
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Hoover Saver 1300 Washer Dryer - drum not emptying fully
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2009 | Washing Machines
Front load whirlpool AWM285/3 washer won't drain or spin
I would suspect that there is a blockage possibly in the pump itself, or the outlet hose from the pump, the other possibility is that the impellor inside the pump is worn or being slowed down by something twisted round the impellor..
If you can establish that there is no blockage any were, then I would change the pump.
Plz rate my solution.Thanks.
Jan 10, 2009 | Washing Machines
Not emptying
what that signals is the impellor on the end of the pump is jammed or loose. Check to make sure it is free.
Jun 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Water not draining
Usual causes are: 1. Something in the drain path blocked. Symptoms: You can hear the drain pump running at the appropriate bits of the cycle, but if you you open the door the instant the pump stops, there is still a pool of dirty water in the bottom. Solution: Follow the path from strainer through drain pump to drain hose, find and eliminate the blockage. Most likely points are the strainer and the inlet to the pump. Hint: You can identify the drain pump by following the drain hose and seeing what it's attached to. 2. Drain pump broken. Symptoms: Usually, you won't hear the pump running at all at the appropriate times; if it does run, it won't sound right. Solution: Take it off and open it up, see if something is blocking the impellor (in which case, fish it out). Spin the impellor with your fingertips; If it won't turn at all, you need to find out why it has siezed (may be fixable) can you feel it turning the motor (a very magnetic, "flippy" sensation). If you can't, the impellor has probably become unstuck from the shaft. You may be able to glue it on, but this fix is unlikely to last very long. Use a multimeter to measure the resistance of the motor windings. If madly different from a few hundred ohms, again a new motor might be necessary. Hint: The pump motor and impellor can usually be bought separately from the pump housing as a much cheaper unbranded part. 3. Back-siphoning from the waste plumbing. Symptoms: You can hear the drain pump running normally at the appropriate times, and if you open the door the instant the pump stops, the machine appears to be empty, but then quietly fills up with dirty water. Solution: There is meant to be an air break (or in some installations and anti-siphon valve)where the machine's drain hose enters the domestic drainage drainage system. Unblock/unjam this. Hint: After fixing this, run the machine empty on the hottest, longest cycle it has; some of that dirty water may not originally have come from the dishwasher. A.
Apr 21, 2007 | Candy 24 in. CD623 Free-standing...
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
