Question about Samsung YP-T8 Digital Media Player
Menu will not display.
After downloading a picture the screen will not display the menu. Only the picture that was downloaded is displayed. I do not want to it the reset button or I will lose everything I have saved. What can I do to fix this problem. Please help?
    President:
  • 3,130 Answers
You may not have much of a choice. Look in the insruction manual on how to save to a compter> try to save all the datas thats on that drive and then do a reset. If that dosent work then try calling the manufacturer and tell them your delima . Maybe they have a secrit button pressing wayt to reset without loosing data? 1-800-SAMSUNG. Good luck
Posted on May 07, 2006
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
No image shows when I take picture
Usually the photo is displayed for a short period of time. Try the setup in the menu. There should be an option for previewing recent pictures.
Jun 20, 2012 | Fuji FinePix S2 Pro Digital Camera
Phone wont ring
Press MENU/SELECT to display menu when in idle mode.
Press up/down to reach Setup HS. Press MENU/SELECT.
Press up/down to reach Rin g volume . Press MENU/SELECT.
Press up/down to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
The screen displays Stored and youll hear a confirmation beep.
If you need a manual, you may download one here.
Feb 17, 2012 | Vtech Cordless 6041 Phone
I do not know how to set the time stamp for my FUJIFILM S1500. The date appears on the display screen when I view the pictures I have taken, but no longer appears once I download them to my computer??
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
  1. Connect the camera to the printer and make sure the printer is on.
  2. Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
  3. Press the DISP/BACK button on the camera
  4. On the menu, select the PRINT WITH DATE option and press MENU/OK.
  5. Press MENU/OK again to start printing.
May 04, 2011 | Fuji FinePix S1000FD Digital Camera
Sd600
press the function button and change the picture size to postcard-there is only one setting that allows you to do date and time stamp-once you have rigth pic size setting-pretty sure it says postcard-go back to menu and you will see date and time highlighted on menu
Sep 06, 2008 | Canon PowerShot SD600 Digital Camera
Deleting unwanted pictures
I have two suggestions. First, you can tag a bunch of your photos on the camera, and then delete them in one operation. You can also delete all the photos on the camera in one operation. This is explained in the owner's manual on page 45 (can be downloaded from www.samsungcamera.com): Deleting images 1. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button. [Select] : Selection window for an image to delete is displayed. - Up/ Down/ Left/ Right : Select an image - Zoom T Button : Select the image for deletion. (V mark) - OK Button : Press the OK Button to display the confirmation message. Select the [Yes] menu and press the OK button to delete marked images. [All Pics] : Displays confirmation window. Select the [Yes] menu and press the OK button to delete all unprotected images. If there aren?t protected images, all the images are deleted and a [No Image!] message will display. 2. After deletion, the screen will be changed to the play mode screen. My alternative suggestion is to use a better program on your PC for downloading and organizing photos. You can get a really nice (and free!) one at www.preclick.com. When you download photos using this, it gives you the option of deleting the downloaded photos from the camera at the same time.
Apr 07, 2007 | Samsung Digimax i6 PMP Digital Camera
LCD screen displays menu items but will not display picture capture & won't take pictures
A very common problem with many Digital cameras. It sounds as if you are suffering from either a CCD problem or a video board problem. Impossible to tell without it being on the bench to check. You could dismantle it and check there's nothing adrift such as flat ribbon cables in their sockets or loose plugs and sockets between the printed circuit boards. Watch out for the flash unit it can give you a nasty shock if it's charged. Most cameras seem to built to last as long as the warranty and then die. This keeps you coming back for more. At least you were lucky to get 2 years out of yours before it passed on.
Jul 12, 2006 | HP Photosmart M307 Digital Camera
Samsung YP-T8 Digital Media Player Logo
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
