42" Phillips LCD HDTV won't turn on. Model number 42PFL7532D/79
tvtek
  • 1284 Answers
SOURCE: Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Posted on Feb 23, 2007
localwonder
  • 6784 Answers
SOURCE: We had a power outage and the next day all I could get on my TV was the blinking power light. Can you hellp me? I have a Samsung 42" LCD Flat Panel HDTV Model No. LN T4042N edit
Hi, the power surge has destroyed the power supply board that is located inside your lcd cabinet. this board works in conjunction with an inverter board that regulates the raw ac current that is used for many different functions in your set. Normally, this type of damage will be isolated within the power supply but, it could have spread to the main control board as well, depending on how well the surge protector preformed during the surge.
The good news is that, this is a repairable situation. you can replace the power supply circuit board and inverter board as well. these replacements will fix this issue.
please rate and god bless:)
Posted on Apr 18, 2009
SOURCE: How do I change a power board on a 42 inch Olevia lcd hdtv. Model: 242-t11
take the back off. find the board that ac cord is connected to.there are six screws,four plugs and a ground wire. carefully remove the plugs without breaking any of the wires.(the first time a plug is removed it can be quite hard to get out.) then remove the six screws and the ground wire connected to the chassis.lift out the board replace it with the new one and reverse the the instructions.
retired tv repairman
Posted on Jun 08, 2009
  • 53 Answers
SOURCE: i have a phillips 42 inch lcd model 42pfl7422d
Hello Mendez the problem that your tv set is having is coming from the inverter board this board provides the high voltage for your backlight without the backlight no picture, what i want you to do is go online sometimes this happens go online look for the service manual for your tv set once you find it get it look for the inverter boards location and check the fuse that is on that board sometimes they blow and it will give you this problem if that is your problem you save money and the hassel of taking it anywhere to get it fixed,if it is not the fuse then the inverter board needs to be changed out and that will fix your problem thank you hope this helps.
Posted on Aug 19, 2009
rulds2008
  • 3866 Answers
SOURCE: my digital lifestyles 42 widescreen lcd hdtv won t power on
PLEASE NOTE IF YOU HAVE NO EXPERIENCE IN TV REPAIR SEEK OUT LOCAL TECHNITION OTHER WISE CHACK THESE THINGS BELOW.
1. check power supply
2. fuses
3. inverter.
Make sure you have no bad capcitors a bad capcitor is a leaking one or bulging at the top or sides if that is the case please replace them.
thanks
Posted on Sep 17, 2009
Testimonial: "Thanks for this general insite. I'll seek a repair service and see what can be done."
Won t turn on
What model is it ? Explain "Won t turn on ".
Aug 31, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Tip
REMOTE CONTROL CODES FOR THE INSIGNIA TELEVISION MODEL: 42" NS-LCD42HD
This information was found on the insignia website www.insignia-products.com under technical information for the insignia television model :42"1080p NS-LCD42HD. cablevision-ur2-cbl-cv04.gifaligner.gif CableVision UR2-CBL-CV04
code: 096
charter-digital.gifaligner.gif Charter DIGITAL
code: 0463
comcast-m1057.gifaligner.gif Comcast M1057
code: 0463, 10463
cox-cox.gifaligner.gif Cox COX
code: 0463
direct-tv-rc23.gifaligner.gif Direct TV RC23
code: 10463
dish-network-vip508.gifaligner.gif Dish Network VIP508
code: 720
dish-network-vip622.gifaligner.gif Dish Network VIP622
code: 720
motorola-drc800.gifaligner.gif Motorola DRC800
code: 0463
one-for-all-urc-6690.gifaligner.gif One for All URC-6690
code: 0464
phillips-pdvr8.gifaligner.gif Phillips PDVR8
code: 115
phillips-ph5dss.gifaligner.gif Phillips PH5DSS
code: 115
phillips-ph5dvd5.gifaligner.gif Phillips PH5DVD5
code: 115
phillips-pmdvr8.gifaligner.gif Phillips PMDVR8
code: 115
rca-rcu807.gifaligner.gif RCA RCU807
code: 135
sony-rm-vl600.gifaligner.gif Sony RM-VL600
code: 8043
tivo-hd.gifaligner.gif TiVo HD
code: 0091
tivo-series-3.gifaligner.gif TiVo SERIES 3
code: 0091
on May 23, 2009 | Insignia 42" LCD Flat-Panel HDTV
Sony 42" won't turn on
TWO things to look at---inspect the lamp this model should use for brightness. Look to see what lights on front of set are on or BLINKING.
Jun 08, 2012 | Sony Grand Wega Kf-42we610 42-inch...
My 42" flat screen phillips
I'd post TV model number first - it's on the back of the TV -and I'd also post a picture if I could.
The lines on the screen do not usually go with the "channel not available" problem and the likelyhood of you having both at the same time is , well, small.
Sep 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
I need the code for the phillips universal remote for the insignia flat screen
Remote control codes for your TV can be found here. Search for your TV model number and click the Support tab. If your remote isn't listed, try codes for the brands listed in the note at the bottom of the page.
Sep 19, 2009 | Insignia 42" LCD Flat-Panel HDTV
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
My phillips 42" HD Flat screen won't turn on
I switched the power cord with the one to my desktop monitor and it worked ..i noticed the end going into the TV had some discolor to it ..I put the one from the TV into my desktop monitor ..and that worked too..must of been a shortage of power from the cord to the TV?
Jun 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
Phillips 42 inch LCD HDTV w/HDMI
I CAN'T TURN ON TV
WHEN TRIED TO TURN IT GOES OFF
I SEE RED LIGHT BLINKING ALWAYS.
Dec 11, 2007 | Philips 42PFL5332D 42 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
