Question about Dell Inspiron 1501 Notebook
Is it safe to use the battery?
Is it still safe to use the laptop even if the battery is that...i mean i can still use and charge the battery im just worried about the warning as i open the laptop...about the warning...how long can i use the battery with that warning...:-) i hope i can still use it longer....:-)
  • 68 Answers
Ya absolutely no problem with that
Posted on Sep 13, 2008
Battery
Eventually your battery will have a short/no life indeed. Though this happens to all laptops.
Using your laptop while it is charging isn't going to damage anything. It just means that the battery will take longer to charge because you're using the laptop.
To get the most life out of the battery, fully charge it and then use it until it is empty. It's also a good idea to remove the battery when the laptop is connected to the mains supply.
All you're trying to do is extend the life of the battery. The day will come when it holds a short/no charge.
Jun 09, 2013 | Lenovo Computers & Internet
"Consider replacing your battery"
Modern batteries do talk to the laptops and provide information on health. Ordinarily, this message would mean that your battery is on its way out. If however, it holds its charge then fine, but at some stage you may find that you only get a few minutes use even on a full charge and you will need to find a replacement.
Leon
Feb 09, 2013 | Packard Bell Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
Why will the battery not charge?
To test the laptop:
Nov 27, 2012 | HP G60-120US Laptop
Dell Xps 15 Laptop Battery Not Charging
To test the laptop:
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
HP dv6-2110 won't boot up- 'Hard disk does not exist' I've had my lap top for just over a year. Its been working great! Was fine all sunday morning, then when i came to turn it on to use...
If the battery of the HP laptop is not in a good condition, sometimes booting problems might happen. To remove any static charges accumulated in the battery, you would have to remove the battery and press the Power button for about 25-35 seconds. Then reset the battery. Even after this, if your laptop is not booting up then you could perform the battery calibration and press F8 key to boot in safe mode.
Jul 27, 2011 | HP Pavilion dv6000z Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
Thanks again...
Sometimes, the battery alarm is set to high or off and it will automatically warn you when the battery is at a certain percentage. Most newer laptops will even warn you when the battery is going bad.
The AC cord is both the power cord and it will also charge the battery when plugged in as well.
So, it's safe to run on just battery as it may just be telling you that it doesn't have AC power and that you're running only on the battery. My Satellite laptop is setup to warn you when it's only on battery power as well.
Sep 16, 2008 | Dell Inspiron 1501 Notebook
Power up
i think urs battery get damaged....
but before replacing it first remove it safely n again fix it on laptop....
then restart ur laptop if same problem is coming...than it is sure dat ur battery get damaged or its efficiency get lower....
send me feed back if ur facin more problems wid ur laptop at shriii2@rediffmail.com
Jun 13, 2008 | Compaq Evo N610C Notebook
Dell Inspiron 1501 Notebook Logo
Alun Cox
