Since I've hooked up my internet my phone has gone dead. It is not an outside problem. My phone was fine before I pluged in the dsl. I have disconected the box and tried pluging in just the phone and that failed. What next?
  • Coss May 11, 2010
    Have you tried a different phone? Just to make sure it isn't the phone its self that is bad.
    Problem Solver:
  • 6 Answers
Contact your service provider and ask them to put a filter in your customer service access on your outside phone interface sometimes the dsl will over power the line filters and keep your phone from working try unpluging your dsl and all your phones for 5 min then pluging just 1 phone in and see if you have a dial tone
Posted on Sep 12, 2008
The router needs to have a modem to run off from, Even DSL provides modems if you do not have a modem then your DSL ISP (Internet Service Provider) did not provide you with one. I would suggest to follow the ethernet cord and see where it plugs into. You will need a modem to use a router.
Feb 18, 2011 | D-Link DIR-615 Wireless Router
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Cant remember how to hookup my router. have blue and yellow plugins. what do they hook to? back in the router ?
In general, there are only two connections on a router. One is usually designated Internet or WAN, this port is a single RJ45 connector and should be pluged into your internet. From either your DSL/CABLE/SAT internet modem.
The other connectors, usually 4 or 8 are the connectors for hooking up other computers or devices. These can be used to wire in your PC, Xbox, Printer ect.
Hope this helps
Feb 21, 2010 | Belkin Computers & Internet
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Feb 08, 2010 | Computers & Internet
Router works then knocks main computer off
internet service went dead and service was restored
Sep 13, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
May 07, 2009 | Actiontec (GT701) Modem
My phone has been out for some time. Just noise on my phone. the outside plug in works fine, so I assume it is my inside wiring. This morning I unplugged all my phones, and hooked them up one by one. ...
Replace the DSL filter. it is needed to in order to prevent interference between phones and DSL service operating on the same line. Without the installation of DSL filters, high-frequency signals or echoes from analog devices can result in reduced performance and connection problems with DSL service, and the high-frequency signals from the DSL service can result in line noise and other issues for analog devices.
Aug 20, 2008 | Lands Phones
No DSL or Internet light
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
May 20, 2008 | Zyxel Prestige 660R Router (91004397002)
Phones Dead but DSL OK
A short inside the house should also disable the DSL service, but you can rule out this possibility by disconnecting the inside wiring from the outside wiring at the entrance box. If you still can't get a dial tone when you clip onto the incoming wires, then you need to contact your local phone company to have them find the problem and restore your phone service.
Good luck...and I hope this is helpfull!!
Jan 26, 2008 | Lands Phones
Westell Linksys 327W
Ok right I love these issues. Here we go!! First I want you to determine if this is a no sync issue or if this is a no route issue. Know this is the difference between working with Verizon or working with Verizon On-Line. If you have a sync issue which means the DSL light is off or blinking, this would be a Verizon proper issue and is easy to have fixed, however if the DSL light is on and the internet light is off this means that you have not received a PPPoE derived address and thus while you have DSL (Digital Subcriber Line) sync you do not have connectivity to a gateway router to route you to the Internet. I want you to log into you DSL modem ( then using your login ID and Password the one you configured for the Router not Internet access. And the go to the screen that show your DSL connectivity see if it is up or down *Remember DSL refers to the layer 1 connectivity, and PPPOE refers to the layer 2 connectivity". If the DSL light is on this meaans that you have to call verizon and say "My DSL light is on, but I am not getting an IP address which means my layer 1 connectivity is working, but my layer 2 PPPOE connectivity did not provide the platform for my layer 3 level to be built". so this now becomes a task of troubleshooting the layer 2 systems (PPPOE server, and IP Address delivery systems, and Redback SMS). Instead of a half hour of "is your modem plugged in". If your DSL light is off then your layer 1 systems are not working this could be anything from your modem to the ASAM ( ATM Subscriber Access Multiplexer ) system or DSLAM (Digital subscriber Line Access Multiplexer). In any case if the DSL light is off they just have to figure out why. This can be done at the central office by disconnceting your cable and pair and trying to sync up at the vertical shelf (Ca/Pr) or at the split bank. If they sync up the problem is outside, if they do not sync up the problem is inside the CO either at the Split bank or the DSL OE block. If the problem is in the CO they will fine and fix it. If the problem is outside, what you can do to expedite things is to take your DSL modem to the NID (Network Interface device) and connect to the phone line that has DSL on it and try to sync up there. If you can sync up the problem is inside of your house, if you can not sync up the problem is outside of your house prior to the NID and thus is verizon's responsibility. I hope this helps.
Sep 06, 2007 | Westell Wirespeed VersaLink...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
