Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
Gateway Monitor We have a Gateway 17'inch LCD monitor and in no particular sequence the monitor will blink on and off, and go completely black and the green power light will also go off. We have changed the power cables and this still has not solved the problem. What else could be wrong?
  • darkanimekid Apr 18, 2009
    my cable is cut on my gateway monitor 17in model No:FPD1520 i am look to replace the cable which is a E1199332 AWM 2919 80C 30V VW-1 low voltage computer cable copartner but the problem is finding this cable and one that will replace the old one in the monitor. I have no idea where to look for a new one. plz help
  • Gateway Master
  • 5,568 Answers
Unfortunately, the power supply is internal to the monitor and this is the likely problem.
It is of the 'universal' input type that is compatible with a range of  90-264 VAC 50/60 Hz indicating that it is a 'switched mode power supply' and these have a design problem that makes the reliable operation of the supply doubtful unless a certain weak point (electrolytic capacitors in the feedback path) is properly attended to.
The run-of-the-mill capacitor in this useage is subjected to high ripple currents which can cause a cheap capacitor to chemically break down, dry out and then finally fail to pass enough signal to keep the supply running or enable it to start up.
If you are adventurous, you can open the monitor, examine the components near where the AC power cord terminates and look for vertically mounted, cylindrical parts with shrink wrap bearing the values and an exposed, scored, aluminum top.
Sometimes, the top will bulge or the base at the board may show signs of crystalline deposits.
If you find no parts that appear as described, the alternative is to find a tech who owns a capacitance meter with DF (loss) function. So equipped, the failed part is fairly easy to find.
The values of these parts will lie between 4.7 to 100 uF with voltage ratings of 6 to 35 VDC.
Defective parts need to be replaced with special capacitors that are rated for high frequencies with low losses. These parts cost a few pennies more and most companies don't seem to care about the eventual failure of the inferior parts since it will typically happen after the warranty expires.
Posted on Sep 12, 2008
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
http://en.wikipedia.org/wiki/Capacitor_plague
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
The display on the screen is jumping and does not hold still. Can this be fixed or is it time to replace the monitor?
A "previously-owned" 17-inch LCD screen probably will cost $30 to $50.
A brand-new 17-inch LCD screen is hard to find -- probably, nothing less than 19-inches is being sold, for $100 to $150.
An audio/video technician will charge $60 to $75 per hour to try to repair your LCD.
So, responsibly recycle (or "free-cycle") your old screen, and purchase a new 19-inch screen.
Jun 20, 2011 | Gateway FPD1760 17" LCD Monitor
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Jul 17, 2009 | Gateway FPD2275W LCD Monitor
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
17 in Widescreen Mag Innovision
Dear tfollis
Have you checked the HZ that you are using the monitor in windows ? If set at a very high level (for example 100hz) it may damage the monitor as it is not supporting it. (and maybe this explains the reason for the shutoff as a means to protect the circuitry)
17 inch TFT/LCD Widescreens monitors are ussualy optimal at 1280x800@60Hz.
Right click on Desktop-->Properties-->Settings-->Advanced-->Monitor--> At this point check the Monitor Refresh Frequency.
Check this first and if this does not solve it then we can proceed to more serious hardware troubleshooting.
Regards
EngineerGR
Apr 30, 2008 | Mag Innovision LT776s 17" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
443 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
