Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore progressive upright canister vacuum
My vacuum has begun to make a high pitched squeal when in use...the suctions does not seem to be affected by it but it's pretty loud.
Please help.
Thank you, Trish
  • Anonymous Oct 16, 2008
    I have a similar problem. The noise isn't high pitched though. It's more of a blowing sound like if you held the hose to the skin on your hand. I thought the vacuum was beltless so that wouldn't be the problem. Any suggestions?
I had the same problem and so my husband took our vacuum apart. I cleaned what I could and discovered that there is a foam filter that sits below a dark gray cover immediately beneath the bag (on the floor of the inside of the vacuum). This is different from the HEPA filter. I cleaned this off (ours had a lot of dog hair on it) and placed it back in the slot. The vacuum is not making the noise anymore and the suction is even improved. I had not noticed the suction had deteriorated as the vacuum still worked well in my opinion. I hope that this helps and that you have the same problem. It was very easy to fix. I believe the noise was due to the impairment to the suction. Good Luck!
Posted on Dec 31, 2008
  • Anonymous Nov 23, 2017
    That did it, thanks.
    Problem Solver:
  • 7 Answers
I have the same problem with the same age Kenmore. I checked for clogs but there were none. The loud noise sounded like a vibration. The noise was so loud you almost couldn't be in the house when using the vacuum. What I found was, the outer rubber housing of the motor/fan was held together by electrical tape and split at the electrical tape (wow, that's a surprise!!). I taped the housing together with fresh tape but the motor housing continued to split when the filters got slightly clogged and higher pressure was generated inside the motor. I suspect that the split was causing some amount of air from the motor to be exhausted into the inside of the vacuum causing internal parts to vibrate and resonate.
I haven't been able to fix this problem. Unfortunately, the excessive vibration caused a control board to fail which controls the agitator. At this point the vacuum is useless. Poor design by Kenmore so I doubt it can be fixed.
If you know of a solution, let me know
Posted on Dec 05, 2008
    Scholar:
  • 55 Answers
Hello, Trish. It sounds like the belt needs to be replaced. You can purchase a belt for you vacuum at any Sears or probably even a local department store and are very easy to replace. Just go to you local Sears and ask an employee to direct you to the vacuum accessories department and you should find the replacement belt. Be sure to write down the model and what type of vacuum it is (i.e. Type U, Type Y, etc.). Hope this was helpful. Please take a few seconds to rate how helpful this suggestion was. Thanks and good luck!
Posted on Sep 12, 2008
Floor cleaner has stopped suctioning. High pitched squeal, hot smell
it is probably just trash that can not be fixed but for the same price as a brand new one due to the amount of parts that will need replaced
Mar 18, 2014 | Hoover Vacuums
Making loud high pitched noise and no suction. Belt seems fine
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
Jul 08, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
HI I have a Bissell Pet Hair Eraser it has a very loud high pitched squeal, I have removed the belt & cleaned it with no effect. Is there something else I cn do? Thanks Joe
The belt may be stretched out and therefore, no good. You can try roughing up the surfaces the belt rides in with some 150 grit sandpaper. That may do the trick
Feb 02, 2011 | Bissell Upright Vacuum - The Pet Hair...
HIGH PITCHED SOUNDS WHEN VACCUUM IS ON
Remove all filters and turn on the vacuum cleaner and check the hose for suction.If it has good suction turn it off and remove the belt.Turn it back on and if the noise is still there you have a motor bearing squealing.It's probably time to replace the vacuum cleaner if you have a motor problem.www.sewvac.com .Most of these box store models are designed for replacement if a major component fails.
Jan 28, 2011 | Bissell Vacuums
Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Dec 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lost suction high pitched squeal
the motor or the fan needs to be replaced.both are a lot of money.
Jul 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Less suction and high pitch whine while vacuuming
most any vacuum repair shop will be able to remove the obstruction causing the problem
Jul 29, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
666 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
