Question about ViewSonic PJ458D DLP Projector Multimedia Projector
VIEW SONIC PROJECTOR IS NOT STARTING UP
My viewsonic projector DLP PJ503D IS NOT STARING UP ,WHEN TURNED ON IT GIVES BLINKING ORANGE THEN GEEN COLOUR THEN STOPS
  • jvol20 Sep 23, 2008
    I'm having the same problem with my PJ458D projector. Lamp will not turn on.
  • mlcompound Nov 21, 2008
    Mine is doing the same thing. When I hit the power button it will flash green and make a faint clicking noise for a couple seconds. It will repeat that a couple times then show a red lamp light (near the menu button). Then it will flash orange and repeat the whole process again. After a second try it will go back to standby. Please advise. Should I just get a mew lamp?
I am having the same problem. Need help
Posted on Sep 23, 2008
Sounds like it needs a new bulb
Posted on May 05, 2009
I want to use my projector for my Xbox but when I hook it up it has no sound. There also is no audio port in the back of the projector for the Xbox auxiliary cords. How do get the audio to work?
If there is a port for computer audio (3.5mm jack) you can buy at converter for RCA stereo to headphone jack. These can be bought at mostly any radioshack. This is what you'd be looking for:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200418&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Cables-_-STARTECH-_-12200418
May 09, 2011 | ViewSonic PJ503D DLP Projector
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
What cable or adapter do I need to connect my projector to a MacBook video out port?
You will need a Mini-DVI to VGA adapter. Apple sells this item through their online store.
http://store.apple.com/us/product/M9320G/A?mco=MTY3ODQ5OTY
You will also need a male to male VGA cable to attach the adapter to the projector.
You can find modestly priced cables at monoprice or other retailers. example: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10201&cs_id=1020102&p_id=2898&seq=1&format=2
Plug the cable into your projector and then plug the adapter into your MacBook. The MacBook will automatically resize your picture to the appropriate resolution for the projector.
Enjoy!
Feb 27, 2011 | ViewSonic PJ503D DLP Projector
How do i reset the lamp hours on viewsonic pj503d i cant afford another bulb right now and i know theres a way to reset it just trying to buy some time untill i can afford one thanks alot
Though you can reset timer in the info menu it is unwise to do so as the bulbs can explode if they go past there usage time and can cause damage to projector.
Have a look on ebay there are a lot of bulbs on there maybe you can find a cheap one.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | ViewSonic PJ503D Projector Lamp
Lamp is blinking like a strobe light
Hi please follow these steps:In a world of PowerPoint presentations and the latest digital downloads, the overhead projector may seem obsolete. The fact of its continuous use in schools and colleges across the nation shows the perseverance of this classroom essential. But, when it breaks down...then what? Look below for a few tips on how to repair an overhead projector.
  • Ensure the wire is not loose from the plug by tugging gently on the cord. Cover any exposed or frayed wires with electrical tape, get a new wire and plug if there is significant damage.
  • Step 3Remove the top of the projector and compare the wiring with the diagram in the projector's manual. Check all the wires are connected as listed and none are missing. If you don't have the original manual use the model number located on the back label to get a replacement online.
  • Jul 27, 2010 | ViewSonic PJ503D Projector Lamp
    Lamp timer reset on my veiwsonic pj503d
    hold the up button ( on the actual projector not the remote ) for 5 sec and then press auto
    Sep 07, 2008 | ViewSonic PJ551 Multimedia Projector
    Bulb doesn't light
    yip, sounds very familiar
    steve, does the pj lamp try to fire up.
    does it briefly light up then shut off
    these are the typ. symptoms of an expired lamp
    Feb 26, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
    822 people viewed this question
    Top ViewSonic Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
