Question about Sanyo DS20930 20" TV
Problem with image, one bar across middle of screen
Hi, my TV turns on, I can hear the sound and change channels. My problem is that there is no picture, only a small section in the middle of the screen that has activity going on. What can possibly be wrong? Is the problem something that I can fix? If so what replacement part do I need? Thanks, Jaime
    President:
  • 3,130 Answers
If you small section is from side to side then you have a vertical sweep falure and is probably the vert output IC. If you have experience with tvs then you know what to do if not then i would highly recomend that you take the set to a repair person for an estimate as theres 100's of volts inside the set even if its unpluged. Good luck
Posted on May 06, 2006
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
What is causing PZ550 Plasma TV to display a frozen image with bars, and then a black screen after restarting the TV? Sounds and TV functions work.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 08, 2015 | LG 50 50PZ550 50 3D Plasma TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Black square in the screen
you have the text mode on . make sure cc is turned off
Jun 26, 2009 | Samsung LN46A650 46 in. LCD HDTV
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
Tv screen goes blank with a line across middle
Hi Andy.
This is a straight forward repair & wont be expensive.
The problem is either dry joints on frame chip or component going thermal and failing at a certain temperature.
Cost for repair will be between £35.00 to £55.00 ask for a quote first.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | RCA F32648 32" TV
Sanyo DS20930 20" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
