I have a indesit wi121, now the problem i have is that the powder compartment keeps filling up with water all the way through the cycle resulting in my washing still being soaking wet at the end of it.
    Genius:
  • 1,239 Answers
HI  Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
 To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
Regularly clean the top and door of the washer to prevent the buildup of dirt and detergent. When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas.
THANKS...........
Posted on Sep 12, 2008
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
Wi121 fills ok then trys to start drum is not turning dial gos round and flashs
check the belt if it's ok check the heater if its ok check the time of the water filling it should not exeed 3 to 5 minutes
Feb 10, 2014 | Indesit W 123 Front Load Washer
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
I put powder detergent in salt compartment in my dishwasher by mistake. What do I do next?
Just flush it out by pouring plenty of water into the receptacle. You don't have to get every last trace out. Make sure to wear rubber gloves and possibly eye protection as the powder is caustic and so you need to avoid skin and eye splashes.
You could alternatively leave the salt chamber cap off and run the dishwasher empty for a couple of cycles; that will allow the powder to dissolve without any chance of you getting splashes on your skin.
Nov 13, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Indesit wax120 dial keeps turning and clicking when attempting a wash cycle. Does this on all cycles. Water enters the powder drawer then dial just starts to rotate and click on every setting.
these machines are a pain for this. you can only check the obvious - check filter not blocked, power up pump independantly and check it works, check heater element. if all these ok then fault is probably in module - if so, not worth repair
Jun 18, 2008 | Indesit Washing Machines
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Drum filling up
Could be anything, Programmer, Pressure switch, etc.. Depending on age of machine. If more than a few years old I would check to see if the pressure switch tube, or reservoir, is blocked with powder or gunge. Tom.
Mar 02, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
