Question about AOpen XC Cube EX661L (95EZ619321) Barebone
Comp won't boot after installing new ram. possible motherboard problem?
I had a 512 MB ram stick installed and I got a new one. i put the new one in the second slot and when i turned the power on, the fan came on, the red light on the motherboard came on and it made these long beeps. my monitor wasn't getting a signal. i removed the new ram and tried again, but it still wouldn't boot up. i really hope i didn't short the motherboard out.
    Problem Solver:
  • 7 Answers
Try emoveing both sticks and blowing into the ram slots then replace 1 stick at a time. if this dose not work try checking all the cables to make sure nothing got knocked out of place when you installed the memory in the first place. (bleeping sounds can mean a lot of diffrent things if the problem carrys on count the bleeps and look on google to see what that number of bleeps means for your motherboard) hope this helps
Posted on Sep 15, 2008
Hello i can't install a AGP 512 videocart I bought
your computer needs more than the video card ram amount to use a particular video card. if you do not have at least 512mb of system ram, that may be your problem. if you have sufficient ram, then you do not have a powerful enough power supply for the new card.
Nov 22, 2010 | EliteGroup KV2 Lite (V1.0) Motherboard
I have motherboard P6VAP-A+, processsor PIII 1.0 GHz. I have two modules of RAM (128 MB each one). I have bought 512 MB at one module and installed it but computer could not work good. I had problems - it...
Simple test - leave only the 512 stick and go into the BIOS and see if the memory is correctly recognized. If it isn't then it's defective. If it is then download, burn and boot from
http://www.pclinuxos.com/
and run the memtest to be sure. If the memory is ok then you will have to reinstall Windows - it doesn't like the new memory.
Sep 24, 2010 | EliteGroup P6VAP-A+ Motherboard
I cannot install more than 512 md ram in my motherboard nforce4 (DFI). it only boot with 512 mb ram stick. if i install 2 sticks it cant boot
it may be that one of the sticks are bad, try booting with one, then the other one. i had the same problem and it turned out one of the sticks were bad. if thats not the case, at least that narrows it down a little
Jan 15, 2010 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
How do you install 4 sticks of ram? I have 2x 512mb and 2x 1gb. Do I put the pairs in the same color slots?
Yes, there are 4 slots, two colors....put the same ram configuration in the same color. RE: 1 GB sticks go in one color, 512 MB sticks go in the other.
Oct 25, 2009 | ASUS A8N-SLI Deluxe Motherboard
How can i increase my ram in intel desktop board 815
Hey,
Ram can not be increased as it is a hardware component in the computer, you can install more ram or upgrade the current ram modules that are inside the computer.
Feb 24, 2009 | Intel Motherboard
System won'n boot if i installed two RAMs
Is the old ram working if installed alone? If yes then maybe got error or grounded if both ram inserted. Try to blow air the ram slot in the board to eliminate dirt and then try to interchange the position of the ram and then try it again.
Hope this will work.
melnavz
Feb 12, 2009 | ASUS P5RD1-VM Motherboard
ASUS A8N5X Unresponsive after RAM Upgrade
Just to verify, are you certain the new DIMMS are unbuffered? That MB does not support buffered DIMMS.
If so, try to install the old ones in A1 and B1 and the new ones in A2 and B2. See if it will boot. If so, check your system to see if the total RAM is being "seen". Comment back.
Dec 13, 2008 | ASUS A8N5X Motherboard
Not able to install RAM > 512 MB
Try to run a system repair.
Jul 14, 2008 | ASUS K8S-MX Motherboard
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
AOpen XC Cube EX661L (95EZ619321) Barebone Logo
259 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
