Question about Sony KV-27S42 27" TV
Sony KVTS27 audio noise and pops
My Sony 27" TV (model KV-27TS27) has low audio level with crackling and popping noise, that intermittently changes from bad to worse. If TV has been turned on for several hours the problem improves some, but still occurs. This noise only occurs when signal is connected to the coax input. When using the RCA input jacks, the audio is perfect. I have electronic technical training but little tv experience. Thanks for any help.
    President:
  • 3,130 Answers
Your problem is a stand-up printed curcuit pcb it has several mof those small surface mounted caps that always goes bad and the # on the part is SBX1981or SBX1981-51p its part # is 874213400 its about 11 to 15 bucks . Dont try to repair the part as the pcb is eaten up from the caps leaking all over it. Good Luck
Posted on May 06, 2006
SOURCE:
Audio crackling and popping noise for PS3
Might be a problem with your cables. Get new ones.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
My 27" wega was making a crackling noise when I turned it on. Last time I turned it on it made a pop and went to standby, it blinks three times, pauses then blinks again clicks and blinks four times.
pls. check your tv mains plugh is luss canaction
if not then
probulum is in side tv set so pls. dont.use tv again and cont.nearest tv tech.and solve this problum. becous cracking noise is dengered for your tv.set
* you dont. open tv back cover it your self.becous in side tv set very high voltage.
Nov 10, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Kv 27ts27 set works fine except lost color. now black and white
pls check and selact in your tv colour system PAL / NTSC / AUTO
set Auto colour system is Best .
set chennal Auto serch
if not
then problum is in side tv pcb. so repare pcb with nr. thech.
Oct 30, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
POPPING NOISE FROM SONY TRINITRON KV-30HS420
dont use high volt arcing can do lots of damage. unless you can be sure comtng from speaker.
Nov 20, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-20FS120
Do you get sound when you play a dvd thru audio/video inputs?
If this unit has audio output at the back run audio to amp and see if you have audio thru your stereo
Jul 23, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron Color TV - KV-27TS27 circa 1991
there,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Feb 28, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Popping and crackling in my zenith tv
probably the ic responsible for audio output! replace it with a new one
Jan 05, 2007 | Zenith C27A24T 27" TV
Sony KV-27S42 27" TV Logo
191 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
