Question about Hotpoint First Edition WMA22 Front Load Washer
Cleaning where is the filter located and how do i clean it
  • 4 more comments
  • Anonymous Nov 02, 2007
    Where do I find the filter please?
  • pwelch Nov 28, 2007
    where is the filter, the machine is leaking water and i need to clean it, have removed the panel at the bottom front, its not there?
  • Anonymous Dec 08, 2007
    I am getting an error message, outlet pipe error. where is this located on the machine
  • laura_mac Mar 09, 2008
    My washing is **w coming out with dirt on it! Where is the filter to clean? I have taken the bottom panel off the machine but there is ** tray...
  • Karen 68 Sep 14, 2008
    My washer is not emptying and stopping mid-cycle. I suspect that the filter is blocked. Apparently the filter is located in the outlet hose behind the bottom panel at the back of the washer but I'm not sure how you remove it? Any help???
  • willgreeves Jan 04, 2009
    Problem is that machine will not fill with water - has recently stopped spinning - i think drainage pipe is blocked?
WMA 20 Switch on all o/k then the door lock light starts flashing and the cycle stops have to keep re-starting it
Posted on Sep 14, 2009
I have a hotpoint washing machine -the filter is located at the back in the sump hose -you have to drain water out and remove filter to clean it.
Posted on May 24, 2008
    President:
  • 3,130 Answers
Couldnt find that model # but most washers wash the lint down the drain or theres a small screen around the tub that you slide out to clean out lint or debris. You should also look at your owners manual under mantainace and if theres nothing mentioned then theres nothing to clean or maintain. Good Luck
Posted on May 07, 2006
  • 641 Answers
I am not familiar with this machine's model, but in most of the machines the filter is located under the panel in the bottom of the machine (the panel under the front door). You should pull the panel out and you will find the filter there. Before openning the filter prepare a bowl and a floor cloth to avoid water's flooding. Good luck!
How and where does one clean the filter on a defy autodry? I need to check as there is a warning light which i need to check as it does not want to get warm.
https://www.manualslib.com/manual/926961/Defy-Autodry.html?page=7#manual
Quoting:
Cleaning the Lint Filter
The lint filter, which is located behind
the door, should be cleaned after each
load to maintain optimum drying
efficiency.
The filter and filter cover are located
inside the door surround front.
Insert two fingers into the two large holes
and pull the filter cover free of the door.
Remove the filter mesh and clean off all
the lint by gently rubbing the filter mesh.
Replace the filter mesh and then the
cover.
Ensure that the filter is in position before
closing the door.
Cleaning the rear Air Intake Grille
The air intake grille, at the bottom rear of the machine, should be cleaned regularly to
maintain optimum drying performance.
Remove any obstructions and dust the grille off with a soft brush
Defy autodry Owner Manual Unsuitable Materials
Jul 02, 2018 | Dryers
Where is the fuel filter located on a 2000 harley davidson fatboy
To clean the carbureted model's filter, you drain the gas from the tank, remove petcock and filter, clean filter with compressed air, reinstall. The fuel injected model requires that you drain the tank, remove the entire pump assembly from inside the tank, and then replace the filter (it can't be cleaned).
The carbureted model's filter is supposed to be inspected and cleaned every 20k miles. The fuel injected model's filter is supposed to be replaced every 25k miles.
Sep 06, 2014 | Motorcycles
How to clean the filter on my stand mixer cuisinart
Poorly designed filter location (subject to flour dust), easily plugged. No provision for cleaning or user replacement. Best solution is to stick filter material over the filter to provide a pre-filter. You can easilr clean or replace this pre-filter. I used computer filter media with double-stick tape.
E
Mar 06, 2013 | Cuisinart SM-70 1,000 Watts Stand Mixer
I get a message to clean filter. I removed back but could not find filter. Cleaned all visible dust and reinstalled back. Worked great for 2 months and got message again. Next day worked ok again. ...
hi,
To clan the air filter you have to remove the projection unit.You can see the projection unit behind the lamp blast board.There are three air filters in this unit. You have to clean these air filters. I have added the picture which showa the location of air filters. If you can give your email address the i will sent the service manual. Which will help you to remove and clean these Air filters. Remember one thing remove lamp first then only remove the projection unit from the rear side.
OK
Apr 20, 2011 | Panasonic PT-52LCX65 44" HDTV
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
LOCATION OF AIR FILTER, AND HOW CAN I TAKE OUT THE...
how can i clean the air filter element, and where is it located
May 21, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
IM GETTING A MESSAGE THAT SAYS FILTER NEEDS CLEANED. WHERE IS THE FILTER LOCATED?
The filter is located at the intake vent of the internal fan, careful observation of the unit should reveal the location, this location should also be listed in your users manual and correct cleaning suggestions listed, user manuals can be downloaded from the net for free from the Panasonic web sight
Apr 26, 2010 | Panasonic PT-52LCX65 44" HDTV
What is error code c2 11?
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
Sep 20, 2009 | Water Heaters
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Hotpoint First Edition WMA22 Front Load Washer Logo
857 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
