Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax not receiving regularly and not allowing me to send
I have been having problems sending and receiving faxes. I have a separate lien dedicated to my fax, have it set to auto answere and have voice over internet service from IDT. I had the same VIP service with another company but thay went out of business and had no problems.
Please advise Thanks
Willie Miska
wmiska@si.rr.com
  • 234 Answers
Sorry to says this is not a problem with your HP All-In-One printer.
Because VOIP is a service which HP does not support, as the signals through VOIP is digital and the All-In-One only supports Anolog signals.
And that is the main reason that you are sometimes able to send and some times not.
Even if you call HP tech for support they will deny support and ask you to contact your VOIP service provider.
The best person to help you out in this problem is your VOIP service provider.
HP will recommed you to try reducing the speed and to check your fax functionality, but will not assure you of any sucess
Good Luck
Posted on Sep 15, 2008
How can I send a fax through a home phone line? I was given this as a gift and I don't have manual. I was wondering if there was a way I could send a fax through my home phone line, since I don't have a...
A regular old (POTS) phone line will send/receive faxes just fine. If you want to connect it to your computer, you'll need TWO phone cords: one into the wall, and one into the computer, with both connecting into the fax machine itself. Those ports should be marked on the fax.
Feb 18, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
I want to fax over a regular phone line nota dedicated line
Yes you can do that..I have one at home myself on the phone line. As for as setting it up its all in your directions. There is no special equipment, you can call the phone company if you want they can make the ring different if its a fax versus a regular call..but that's the only thing you need to call them for...
Mar 20, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Setup FAX...
Plug a phone cord into the LINE port of your machine. Ideally it should be a dedicated phone number, but you can share a line.
Sending a fax is just like making a phone call.
Load your original face down , dial the fax number, press send or start.
Receiving will be automatic.
Mar 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Can send but can't receive faxes.
if your fax is on a dedicated fax line, make sure your display says "fax only" or "auto". if not on a dedicated line, you'll have to give more info on what kind of hook up you have. in other words, is there an answering machine hooked inline, etc.
good luck,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
Hp 5610 won't receive fax from lexmark fax
Are you able to receive faxes from others from the same location, if not just ask her to consult her service provider and ask to get the no checked of yours why is it that you she is not able to send fax to you only as your fax machine is capable of sending and receiving fax from others it should be dsome issue with her service provider.
If it was your All-In-One printer thrn you should not have received faxes from any one, not a specific number.
Good Luck
Aug 19, 2008 | HP Officejet 5610 All-In-One InkJet...
How to set up 2 fax machines on 1 dedicated line
Set the rx fax to ans on the lowest # of rings and fax mode..Set the tx fax on tel mode..
Feb 20, 2007 | Brother IntelliFax-2820 Laser Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
